won't come up in my version, says invalid model number. Which I think means it was made later than my fast data. Your sure its 2002?
Thanks for your quick response
Was told it was 2002.....could I have needed more numbers for you....ie....another 7 letters maybe..like all other vins?.
Now I am stuck......I will have to check with the importer, check the auction sheet and get back to you
for interpretation....
VIN NO. : 6U9000ECR33102890
Model: R33
Series: GTST Type M
Built: Jan 1996
Colour: Sonic Silver
Body: 2 door coupe
Transmission: 5 speed manual
VIN: bnr32302958
Model: R32
Series: GTR
Built: April 1993
Colour: Gunmetal Grey Metallic
Body: 2 door coupe
Dear SMR33,
Is this FAST program 100% accurate?
My Skyline was imported and complied with a build date of "June 1998". However, I had a feeling this was inaccurate as I remember reading somewhere that R33's finished production in March 1998?
Someone please confirm this for me.
Thanks.
R33's built in 1998 would be the 40th anniversary skylines and as such should have special badging, and interior touches. When production ceased on the R33's I am not sure, however the number I checked for you had a build date of June 1997 (according to FAST). FAST is only as accurate as the information entered into it at the time.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
