  WHITE R32 said:
hello... id love for someone to be able to help me with fasting my vin to identify the vspec/non v spec etc and anything else which may be interesting
BNR32305342
thanks in advance :P
here you go
Your model number is KBNR32RBFSAA. Using the below link to decode all the letters you can see its a vspec.
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
  CameronBNR32 said:
Could I get my vin fasted please, I've got some weird letters in my model code :S
BNR32-003362
KBNR32RXFSLMZG < dont know what the M,Z, and G mean :P
thanks.
I ran your vin through fast and got you this.
To be honest i have no idea what the M, Z or G mean in your model code but i have only ever seen them on r32 gtr's that were built in 1989.
Maybe someone else can shed some light on what these 3 letter mean and why they only seem to be on the model codes of early r32 gtr's??
G'day,
Could someone with FAST do a vin & engine check for me if possible.
The VIN is ECR33135365.
Engine no is RB25277413A
Thanks in advance.
Cheers
Grant
I have been doing a lot of searching around on the forums for the answer to what the last letters mean on the model codes for the early model r32 GTR's (L,M,Z and G).
cameronbnr32 and garrysandy the only info i could find for you guys (and any one else wondering) was a post from funkymonkey back in 2004.
From what i read the letters L and M, which occupy Positions 8 + 9 in the model code, are known as VS Sign (VS Options)...
L means it has Projector Headlights
M means it has both climate comtrol + upgraded stereo
Letters Z and G occupy Positions 10 + 11 in the model code and are known as Pack Sign (Package Extras Sign)...
Z Im still not sure what it means but some guys believe it might be to do with the interior trim. RellikZephyr Thought Z = Black Interior Trim.
Cant be confirmed unless funkymonkey or someone else knows for sure what it means.
G from what i found means ABS and a Viscous LSD
Hope that helps a lil for you guys wanting to know.
Below is funkymonkey's original post from back in the day
  funkymonkey said:
Here's the factory Extras that are indicated by the last 7 characters ona 1989 -1991 R32
VS Sign
Position 1
Blank = Standard Headlight
L = Projector Headlight
Position 2
Blank = Standard
P = Electronic control active Full auto air-conditioner (Climate control system I assume)
Q = Electronic control active Sound System (Upgraded Sound System?)
Z = Cold District Specification
M = P +Q
V = P + Z
W = Q + Z
T = P + Q + Z
Pack Sign
Char	Pos:	1   	 2
A	Standard	Standard
B	4 Wheel Anti Skid (ABS?)  GTR Steering Wheel
C	Sunroof   	 Type M Specification
D	GT Auto Spoiler (Front Only)  Viscous LSD
E	GT Auto Spoiler (Front and Rear)	B + D
F	B + C
G	B + D
H	B + E
I	C + D
J	C + E   	 GTE Special Seat
K	B + C + D	J + Viscous LSD
L	B + C + E
SS 	 V Selection
Position 	 Number: 0	1	2	3	4
1 With ASCD - RB20E RB20DE
  Super HICAS RB20DET 2WD  S	Y  Y
1 Audioless (All Cars) 	 S  Y	Y
2 185/70 tyres + 14 inch rims (CA18i)	S	Y
2 15 Inch Alloy Rims 	 S 	 Y
3 Electric Side Mirrors (CA18i)  S	Y
3 Fender Mirror (All Cars)  S  Y  Y
3 Rear Wiper	S 	 Y	Y
S = Standard (ie. does not apply) Y = Vehicle is equipped with this
  Count Grantleyish said:
G'day,
Thanks in advance.
Cheers
Grant
dont know about doing an engine check but here is your vin
G'day,
Many thanks for checking the VIN for me.
Don't worry about engine check.
Cheers
Grant
makes sense - cause the whole chassis code from the vin i posted ended in LMEC
the car does have the projector headlights (L)
it could have climate control and the upgraded stereo, but they have been ripped out (although some parts are there)
the E corresponds to GT auto spoiler front and rear apparently - and it is a type M r32 with a sliver GT badge on the side
and it does have a sunroof which is a type M spec item
bit of food for thought i suppose :woot:
bit of food for thought i suppose :D
Yeh i tried with my r32 gtst model code. I have the LMEC on the end of my model code and it worked out fine.
I have the projector head lights. I have the climate control and had the "upgraded" stereo. I had the GT auto spoiler and its a type M r32 so thats how i decided it was all pretty right and close to the mark.
If any one definitely knew any different im pretty sure they would soon post in here.
Still dont get why nissan changed everything from 1991 onwards with model code the R32 GTR's . Did make it a lot easier to decode the model code though
Edited by babyskyline
can you do 350Z checks? checking for a friend... have a suspicion a dealer is doing a dodgy, need to know if it REALLY is a "track" model and if it came from the factory with the REAL track rims, the lightweight ones...
EDIT: hmmm... i don't think i've been given a VIN, i've got the engine #
VQ35037314
and this
JNIGAA233A0010029 - being a Zed, should it have a Z33 type code somewhere? - It's OZ delivered obviously
My friend only showed me pics, i saw brembo's but the rims were the non-track rims... the track rims weren't an option were they? I'm just wondering if they saw her coming, maybe did something with the rims, or perhaps the brembo's were an option and it's not really a track model?
is there a button in the cabin somewhere to check for stability control?
the other thing i thought with 'fast' is that if it said it came from factory with the lightweight rims, i would get her to ask the dealer where the hell they went!
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
