Hi guys, I have been meaning to do this since i signed up!
6U9000ERC33029557
Thanks in advance!
Dan
Pretty sure you put the 'R' and the 'C' around the wrong way mate. If you meant to put ECR33 029557 this is your fast mate.
Can some one do this for me?
It is supposed to be a vspec
6U9000BNR32300152
sorry mate not a vspec.
Use this link to decode it so you can see its not a vspec
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Hi again
Still working through the conversion stuff
Could you please find part numbers for
V35 5 speed auto 3.5 VIN is PV35500185 engine loom
Z33 5 speed auto 3.5 VIN JN1GAAZ33A0010030 (gave you it all, just in case) engine loom, ecu and gearbox
Z33 5 speed auto 3.5 VIN JN12AAZ33A0250072 (gave you it all, just in case) engine loom, ecu and gearbox
Regards
Edited by CeffyNSW
OK guys
Too much to ask by the sounds, my apologies.
Working through some wiring diagrams and it should be OK.
Regards
Would appreciate someone doing my v35 2004 sedan.
VIN 6U90000PV35450969. Need to know if it has viscous lsd or not?
Thanks in anticipation. Graeme
You guys should PM "chook". I cant fast v35's.
sorry guys
Can anyone tell me if KBNR32RXFS AA is a normal GTR or V-Spec?
Bought it 5 years ago as a normal GTR, but the chassis plate decoding page seems to indicate it would be a V-Spec. Not fussed either way, it has Brembo's on the front, standard Nissan callipers on the rear and a few other V-Spec pieces in it. It will always be my B-Spec (bitsa everything).
BNR32219986
Cheers :)
If you use the last 6 digits of your vin on the website i use to decode the r32 model codes it says your gtr was built between 07/1992 and 08/1992 so its not a vspec but when i type in your vin nothing comes up. I have to also put in your model code. which confirms it isnt a vspec. Strange because i havent had to do that before. :)
Here is your fast mate
Edited by babyskyline
Cool, thanks for that. I seem to recall that happening a few years ago when it was FAST'ed.
Wonder why it lacks the 7 on the end of the model code which would indicate its a normal GTR, as according to that code site a lacking number means its a V-Spec... *shrug*. It has all the V-Spec running gear and a few other 'mechanical oddities' every reputable GTR workshop I have taken it to has never seen before, so ill keep calling it my B-Spec :)
Edited by Amaru
Im really hoping im wrong but because it has the brembo's, and all the v-spec running gear as you said, and seems to have a vspec model code but has the vin of a car that was made in 1992....it might be dodgey. Im really hoping its not for your sake but it sort of sounds like someone added vspec gear and tried to pass it off as a vspec with the model code.
Well it wasnt sold to me as a V-Spec, but as a normal GTR with Brembo's so im not fussed about that (e.g. I didnt buy it because it was advertised as a V-Spec). Have attached a pic of the VIN plate, it looks real and doesnt look like it has been changed.
I wouldnt be worried about it if you didnt pay the extra for bein a "vspec". As long as your happy it should be fine. Just seems strange to have had the gear put on and a vspec model code but not be a vspec.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
