Here is the fast for chassis: DR30 034944
I couldnt get chassis: DR30 021333 to work for some reason.
Do you have the model code for this one??
thanks mate. So build date is 09/1983?
na not for the 2nd one. bit of a weird car, had a l24e in it with mr30 plates. all the mounts etc look factory 2. cnt see any signs of cut and weld job around the chassis number either. off 2 sims metal soon anyway lol...
Edited by OUTATIME
Heya, could I please have mine done, am trying to work out what diff is in it exacalty because noone seems to know, it has it's own stand alone ecu for the diff and has 2 oil pumps under the drivers side rear, and there is a 3rd one which appears to be attached to the diff, also has a oil top up which is located in the boot. The only thing we can read on the diff is G3HJ08, the rest of it is unreadable.
- ECR33008466
- GGKBRVFR33
Anyways thanks ;)
you almost certainly have the active rear diff, there are pumps that push torque to the side with more grip based on the wheel speeds instead of just a mechanical setup. It was on all 33 Vspec GTRs, and a very few GTSts have the option as well.
they are a good diff as long as everything is working OK, but they can be hard to troubleshoot and repair because very few people know about them, and there are few spares around
Unfortunately I can't get your vin# in my copy of fast to confirm.
Best way to check, you should have an ALSD light on your dash that you would see when you first start the car
Yeah we have the ALSD light and a slip light as well on the dash. Atm we are having issues with it staying on alot of the time. But if we get it out our drive way then turn it off and then basicly move the car as soon as we start it won't stay on. Problem is the ALSD light often comes on when any sensor in the car plays up.
Thank you for your reply, it has helped a little in trying to explain what diff we have to nissan if it is in fact the diff sensor that is running a muck lol.
could someone look into a 6u900bcnr33022973 please as supposed to be limited edition. Thanks!
Appears to be a legit limited edition r33 gtr vspec. The paint code is BT2 - Champion Blue (exclusive to R33 GTR LM)
here you go mate
Edited by babyskyline
can some please do 6u900BCNR33041211, including engine number and options
thanks :rofl:
Nissan Fast cant tell you an engine number.
Here is your fast mate.
You might want to pm Chook to get your options translated as i cant.
Guys I am wondering if someone who can read Japanese can help me out here. I need to get a new door actuator for our Skyline I have fasted the VIN and worked out the part, I have even taken the part out of the car onyl to find that there are not part #'s on it. so looking at the FAST software it give me two parts #'s for the same part. Only thing that differs is the desciption and the dates, but my vehicle was made durint hte over lap of the dates so can someone tell me what is the different between the two parts and what is the correct part for the actuator ie the electronic part in the door.
thanks for any help apologies if this is in the wrong section
Edited by bigafoot
OK, 80552-AA300 is for cars with remote control entry. Other is not.
hope this helps.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
