thanks Chook, do you know what the A, AP and C means in the model, does anyone know?
I have a list for first 13 codes, 14 to 18 are the options, listed for you earlier. eg 'A' in #15 means rear wiper, P in #16 is big spolier. Dont know of any lists the cover codes 14 to 18. Just a matter of translating them.
http://www.skylinesaustralia.com/forums/in...t&p=3718792
can someone please fast
6U9000ecr33103232 and including options
appreciate it very much!
thankyou
Here is your fast mate. You will have to hit up chook to translate your options for you...i cant translate japanese
hey,
Can I get some info on this vin please :D
HR32002953
Also,
Is there any way of finding out what year the car was made?
(have a non- complied import that seems to have alsorts of parts on it)
Cheers,
Is it a non turbo or did you leave out a letter in the vin by any chance??
I couldnt get it to work in nissan fast. Need your model number also if you can get it.
