would appreciate this one getting done BCNR33008451
as much info as possible would be great
thanks
It's marked as "For the Cold Districts" which presumably means it had an optional pack for snow country (R33 experts, help me out here!)
After that, Super Fine Hard Coat and rear wiper are the only two options listed.
could I please get some help on my model codes for the 33 gtr, I'm trying to find out what exactly the car is and what it came with from factory
my model code is GGJPRQFR33ZDA-----
So far I have got:
G - 2 door
GJ - RB26DETT
P - Super Hicas 4WD
R - Right hand drive
Q - GTR
F - 5 speed manual on the floor
R33 - Model
Z - Intercooled twin turbo
D - ????
A - ????
thanks.
Added, not sure on the last two.
BNR32-312893
is this a vpsec? september 94 model
original paint colour?
Thanks guys
where do you get this program from?
Its 94 model so could only be a vspec 2 and its not.
Paint code is 326 - Crystal White
Nissan fast can be downloaded from some websites/torrent sites. Youjust have to look for it
BNV34401570
Hey mate, is this a an R34 VSpec 2 (White) ?
Trying to find what it came with etc etc
Thanks!
Its a vspec 2 and its white.
Options are
Brake upgrade
Super Fine Hard Coating
Advanced Aero System
Privacy Glass
LMRF2 (NOT SURE WHAT THAT IS)
Multi Display Meter
Rear Wiper
Edited by babyskyline
Thanks for that mate!
much appreciated
Hi,
can someone help me find out about my car?
my vin number is 6U90000ER34030470
Many thanks!!
special features:
glove box lamp
insulated uv cut glass
keyless entry
xenon headlights
sunroof
trunk finisher?
rear wiper
colour is "active red"
Edited by SkyHi_33
Anyone? please!
missed your post.
heres a screen shot, the extra little window open usualy tells me what special options came with the car however for me its only ever worked with r34's otherwise i get a bunch of characters like i got with yours :)
sorry bud..
special features:
glove box lamp
keyless entry
xenon headlights
sunroof
trunk finisher?
rear wiper
Hey mate,
one last question from me, is it possible to check whether mine is a series 2 or not? sorrie for all the trouble man. Much appreciated!
missed your post.
sorry bud..
I thought it might of just been my version of fast, oh well. Thanks anyway :)
Hey mate,
not sure how to find that out... maybe someone else on here knows?
hey guys,
can i please get a rundown of ECR33108743
i have a screen print of it that someone did for me a while ago, but it doesn't tell me the factory options and such.
also, does gts25tml mean it has the A-LSD?
cheers
Ric
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
