Sorry guys i have been away on holidays for a while.....
ok, i did a bit more of a search, and came up with this.
on the fast screen shot, where the model number is, if u look at the 6th character along it says Q.
Q = non Vspec
W= V spec
is this correct? if so the one im looking at isnt a v spec.
Yeh mate that is correct. Also in fast when its a vspec the forth line where it says GTR will have GTR/vspec or GTR/V.
Hi people,
Im looking at going to Melb this sat to buy the following. Can someone do a VIN check and let me know what comes up.
1996 R33 GTR V-Spec
Model no: ggjprqfr33
VIN: BCNR33002497
Engine No: RB26050285a
Colour code ano K
Thanks
Cant get yours to work with either the vin or the model code. Might want to recheck it all to make sure thats right.
yeah could someone fast mine cheers
hnr32-001250
model:krnr32rgfslmcb
Here is yours.
Hi,
Me again, maybe I need to get my arse on installing the software (what file do I need to use for Skylines both chassis no and parts)!
I'd like to find out anything special about this chassis no.
BNR32001945 - Supposedly '89 In black.
Cheers
Grant
For all japanese imports the files youneed for fast are A1, A2, A3, B1, B2
It comes up as a black 89 gtr. Here is your fast
6u9000bnr32303621 32 GTR DUDE
Here is your fast too
To decode your model codes you can use this website
http://www.users.on.net/~goofyhsk/info/chassis_plate.html
Hi,
Could somebody please FAST "6U9000BNR32221872". Looking to buy this car within the next few days, very much appreciate some help :angry:
Thanks again,
Sean
Sept '92 GT-R, Colour Code 326, Model KBNR32RXFSAA
buying an R34 In a few Weeks and need the following VIN Fasted.
6U90000ER34007614
Cheers.
June '98 R34 25GT 2-door, Auto, Colour code KV2, Model GGKAREAR34EDA-JF--
I'm afraid I can't translate the special option codes @ characters 15 & 16.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
