  lanky71 said:
R33 GTS/S
Non Turbo RB25
Manual
Couldn't get a colour code i think its because its a non turbo... same as the guy a couple of posts above the vin no. won't recognise had to use model number.
Thankyou, You've put my mind at rest about it being a auto converted to manual, glad it's factory manual at least haha.
  lanky71 said:
March 1997
R33 GTST Type M
Manual
Color field is empty as i believe there is something wrong with your vin.
Cheers lanky, finally got their in the end :D
wierd tho, the guy i bought it off was 100% sure it was a 1996.. its even rego'd as a 1996.
ahwell..
(also the car is white, but i have a suspicion its been resprayed from black)
thanks again lanky + the othes who helped
  URW34K said:
i may have missed it, but is this FAST check limited to skylines only or can s13's be fasted?
Yea I'd say so ....mine is givn me lists of parts 4 s13z
whats ya vin someone will fast it
not quite a VIN request guys, but i'm in need of FAST so thought i'd post it here.
i have what i believe to be an r32 gts-t wastegate actuator.
it has "ASN 79 - 24 *something* 525" on it.
can anyone confirm if this is the correct part number? or what the number for an r32 gts-t actuator is?
thanks a lot :wub:
Ric
thanks a lot :D
Ric
nissan part no.z are usually something like 14483-04U05, I think the 32s had at least 3 different actuators (can't read Jap,sorry)
if you are after the program 4 yourself I'd suggest you google :- 70F6451B09CD69E8758A32264323C8E85CD74910
hope this helps some
Edited by BundyBear
Sigh...... here's a wobbly for ya's to try ..... i just installed FAST , and it correctly pulls up all the info on the VIN's i randomly selected from this thread to try, however, ofcourse, it says mine cannot be found.
ECR33 012643
Its a S1 r33 4dr auto.
Oh and just for a total smack in the face .......... 012642 and 012644 WORK !!!!!!!!!!!!! AARRRGgggggg
Gary
Edited by Fastrotor
I only get yours to work when entering the model number then vin no. but its a general info like ones mentioned above no colour code info.
Just to double check it gave me right info October 1993 built?
I always though it was 9/93 so Oct sounds correct. How do you mean entering model THEN Vin no ? Im new to Fast sorry.
I have to enter ECR33 , then tab to next box and enter the number XXXXXX to get it to work, do you mean this or something else ?
Gary
This is the only date i have on the car, the importers plate.
Edited by Fastrotor
  BIT SUS said:
6U900BCNR33003083
cheers, thanks
R33 02/95
Color # kn6 (Plumb)
Interior :k = Grey
Model :2k
GTR
RB26DETT
5sp Manual
HikeAss
4WD
Model No.GGJPRQFR33ZDA-J---
EDIT:: FYI the 6U900 just means its an import. its not part of the VIN as far as Nissan is concerned, just the RTA, cops n the like
:: ghostflameR33
I could be wrong here ubt I don't thing FAST includes any Engine No data as it's primarily 4 Spare parts
google is GOD
Cheers all
Edited by BundyBear
  BundyBear said:
R33 02/95
Color # kn6 (Plumb)
Interior :k = Grey
Model :2k
GTR
RB26DETT
5sp Manual
HikeAss
4WD
Cheers all
thanks mate, but are you sure on the colour? Mine is Midnight Purple....
yea preety sure, mine is the same color KH2 ( looks gunmetal grey with red and blue 'perl'), the color code is actually on the compliance plate(firewall one, not import plate)), just above the engine type, RB26DETT . See port #1713, his paint code is KH2. This will confirm FAST info, and if the cars has changed color. KH2 is also refered to as gunmetal grey sometimes
PS midnight purple is a rare colour, price me thinks, codes are
LP2 (R33)Midnight Purple (no Chromalusion, has 2 pearl tinters Violet & Red)
LV4 (R34)Midnight Purple II (Chromalusion Tinter KK760 Absolute Purplene & Vilot Pearl)
LXO (R34)Midnight Purple III (Chromalusion Tinter KK700 True Blazberry Prizm & 2 pearls red & Violet)
see Here for ALL the Paint codes
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
