Hi guys,
I am about to purchase my first Skyline and wanted to know if somebody could kindly enter in the vehicle particulars and tell me everything that comes up on it. Help is much appreciated.
VIN: 6U9000HCR32282451
Cheers, Joey
Can someone please check: HCR32-279294
Thank you
HCR32-279294
Hi guys,
Cheers, Joey
6U9000HCR32282451
- October 1992 model
- Spark silver metallic exterior paint
- Dark grey interior
- RB20DET
- HICAS (Rear wheel steering) and RWD
- GTST Type M
- Manual 5 speed
Edited by Dark26
I'm looking at a r32 gtr apparently a ''93 v-spec
if someone can fast this vin for me would be much appreciated
VIN: 6U9000BNR32302418
Your model number from FAST is KBNR32RXFS7AA
X = Standard GTR with the 16" wheels
B = V-spec with the 17" wheels
Which means, its a standard GTR, not a V-spec.
I am trying to find out if this car is vspec or n1
BCNR33-001745
GGJPRQFR33ZDA
Any help would be awesome
It does and thats not an N1. You can identify N1s by --c-- in the model code. Heres mine.
Does anyone know how to identify NURs? I've got one here which I have a hard time checking. Everytime I key in the code it'll change something in the model and manage to find something.
I think its BNR34-40380J and GGJPRWYR34ZZAAAW-D. For some reason I remember someone mentioning the ZZAAA indicates NUR or something. Can some experience Nissan Fasters help? Hehehe. Thanks.
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
