Hi,
I have an RB26 Stagea but not an Autech. Wondering if someone can FAST;
VIN# WGNC34024634
and a separate FAST for Engine # RB26047962A
Thanks in advance.
Regards,
Allan
sorry FAST does not deal with Engine Numbers
Cheers Bundy
Brandon
mine comes up invalid to, thats on the VIN , the model No and using both???
I'm using FAST Ver 3.5 btw
cheers
Same version and I just checked it again it the same as what I've posted. I'm only using the VIN and model I got was KBNR32RXFS7AA.
Can someone check that NUR for me? My mate is looking at buying that. I cant get it out from FAST but for some reason I'm thinking maybe FAST doest show cars that were produced after 2001?
Hmm it doesn't work for me either, says that it is invalid.
Fast this one for me. Thanks in advance!
BNR32001527
Hi,
Please lookup my VIN: HCR32003878
I am mostly interested in month/year of manufacture
Cheers
May 1989
please check this for me, i have fast downloading but may need it before it finishes...
BCNR33023740
mainly wanting to know if its qm1 white
thanks.
Yes its QM1 white
Hi,
Could you please check the following chassis number for me BNR32-304331.
Thanks in advance, much appreciated.
Z54
??GTR.17?? not sure what it is, bit I think I'll like it.
cheers Bundy
what does GTR.17 mean.
Guy claims its a V spec 1
What are your thoughts?
probably not, V Specs are normally listed as GTR/V in FAST like the one below
although I've never seen the 17, so looks like "Something" special, maybe someone else can shed a light
also just notice d the othert 32z I got 'on file' list engine as 'RB26DTT' yours lists as 'RB26DETT"
& your Geabox lists as MT.F5 not MT ... could be Series 2
maybe someone familiar with 32'z might know
EDIT: splelnig
Edited by BundyBear
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
