Thanks, could someone please tell me whether this vehicle I am interested in buying is a v-spec or not as it was advertised as one and has brembos etc but im not sure it is, would it say V-spec instead of GT-R in the FAST results? Thanks very much in advance :(
the vin check tells you the car is christal white (326) with grey interior (G), runs an RB26DETT GTR, 4WD & was built in March 93', if all of this adds up plus it has Brembo Brakes, Retuned ATTESA E-TS system & had 17" BBS wheels with 225/45/17 tyres at some point then you should be pretty right, im not actually sure if the R32's come up as GTR/V on the VIN FAST instead of GT-R or thats just the R34's? can anyone else confirm this?
Edited by azzafreddy
yea 33/34 show V Spec, 32z only show GT-R or GT-R.17
2 check models in FAST type 'r32' in "Model series", click OK,
then the top right button out of the 8 Jap buttons (DU-AD)
cheerz
Can anyone provide either: a page that details which codes relate to which options, or in particular ABS on BNR32, or A VIN of a GT-R which came with ABS from factory using the 1inch brake master (not brembos).
Thanks guys.
Also could someone fast HNR32001765 for me :banana:.
Thanks again.
::Z54
definatly not, I'm not sure what the .17 indicates(I assume it'ssomething to do with 17"Rims), but they are the only 2 posibilities FAST can give
Thanks guys.
your best bet is :- Decode Model Numbers Scroll down a bit
Also could someone fast HNR32001765 for me :thumbsup:.
Thanks again.
Cheers Bundy
Cheers bundy there is no mention of ABS on R32 GT-R model codes and on 33's it appears to be in the same position and the same letter as the 32s steering wheel designation *puzzled*
Similar information is here: http://www.skylinesaustralia.com/forums/Vi...amp;hl=decoding with reference to the original thread which has a dead URL.
It suddenly strikes me.. do all 32 GT-Rs except N1s have ABS?
yea different models are decoded different. pita
I think your on to sometheing there, had a look at Motor Traders (known verified info), looks like all 32 GT-R and GT-R Vspec (including V spec II) have ABS as standard, main options are fog lamps,drivers airbag and rear wiper in later models
cheers
Edited by BundyBear
