Hi all, it has been about a year since I have played with my car and it's time to upgrade the 20.
When giving your advice please take into consideration, Iwill NOT myself be able to put a motor together, pull one out and put another one in. ALSO please look at the mods I already have and what can be utilised.
I basically want expeience on what would be a better way to upgrade and spend money takng into account logevity, power, reliability, whether it's going to be legal on the road.
Power target would be 300RWKW.
The car is a daily drive and has some track days here and there
Prices, power and experiece would be prefered.
Cheers
CURRENT MODS @ 220RWKW
1989 r32 sedan
Standard internals
Apexi FMIC
Apexi Power FC
Garrett 28RS turbo
GTR injectors
GTR fuel pump
Standard AFM
Air pod with heat shield
Spit fire coils
3 1/4 exhaust from turbo
HKS suspension
Upgraded brakes
Heavy patrol clutch
https://www.sau.com.au/forums/topic/128498-rb26-v-rb25-v-rb30/
I think you will strugle to make close to that with the RB20, will do it with a 25 but all you will be able to use is your FMIC & coil packs. the rest you will be able to sell. It is possible to make 250rwkw with a 20 if you squeeze it hard enough, otherwise Rb25 with about 12k worth of bolt ons and labour to fabricate & fit etc. 25 will make this power with standard internals but bolt ons are not cheap. can also make 250kw comfortably with less modification and expense.
Cheers
1989 r32 sedan
Standard internals
Apexi FMIC
Apexi Power FC
Garrett 28RS turbo
GTR injectors
GTR fuel pump
Standard AFM
Spit fire coils
HKS suspension
Upgraded brakes
Heavy patrol clutch
Since you are not going to do this upgrade yourself, what we tell you (parts and prices) is pretty useless. You need to find a workshop and ask them.
Doing it as cheaply as possible, following is an indicator of what I would keep, modify or sell
1989 r32 sedan = keep
Standard RB20 internals = Sell, buy a complete RB25DET
Apexi FMIC = keep
Apexi Power FC = Keep
Garrett 28RS turbo = Sell, upgrade to GT30
GTR injectors = Keep
GTR fuel pump = Keep
Standard AFM = Sell, upgrade to Z32
Air pod with heat shield = Keep
Spit fire coils = Keep
3 1/4 exhaust from turbo = Keep
HKS suspension = Yuk
Upgraded brakes = Keep
Heavy patrol clutch = Keep
Nimso adjustable fuel pressure regulator = Buy
Take the RB20DET inlet manifold off and swap it onto the RB25DET so you can use the GTR injectors. If you haven’t already done it, run a dedicated wiring harness (from the battery) and relay to the fuel pump, that will give it 13.8 volts which will be enough for 300 rwkw. The Nimso adjustable fuel pressure regulator will enable you to stretch the injectors to 300 rwkw by increasing the fuel pressure from 36-38 psi (standard) to 45 psi. I would use new rubber fuel hoses and clamps, 1989 one will be well past it. Ditto the vacuum lines, all of them.
Depending on the current condition of the RB20DET gearbox and how you treat it, it might last a while, but I would budget on upgrading to an RB25DET gearbox fairly soon.
My guess on prices;
RB25DET $2,500
GT30 turbo $2,600
RB25DET gearbox $1,500
Install, wiring changes and tuning labour $3,000 (I added $500 for contingency because shit happens)
Nimso adjustable fuel pressure regulator $150 (Nengun)
Z32 AFM $300
Total = $10,050
My suggestion, sell the R32GTST and buy an R33GTST, it will be cheaper.
:) cheers :)
If you want 300rwkws, and thats more important then the car you are driving, then i woudl consider selling the R32 and buying a neat R33.
There are a few good examples with the mods and power already which are for sale. Ask Wayne to see what he thinks of INASNTs cxar. Im nto sure hwat he is askign but its a nice and grunty R33.
Here here... Sounds like a plan.. Slightly newer whale, better gearbox and motor to start off with without rego hassles.
The only downside you lack the little R32 hard edge race car feel. All depends what you want out of your car and what you want to use it for.
Am definatly going to keep the r32. Just rather than replacing with another rb20 am thinking of upgrading and getting some more power also. It will be mainly a street car with some track work every now again.
Is RB30 illegal for street or going to be too expensive, was thinking lots would have suggested it.
Cheers
single turbo RB30(25)DET only requires normal road worthy and emmissions test for legal rego (according to SA statment of requirments) but RB30(26)DETT would require bigger brakes, weight to power ratio test, etc. given that both engines look stockish with all the extra bits that do nothing but look like they make it economical.
A single turbo three liter twin cam is considered to be the same as a VL turbo and R32 gts-t has better brakes than a VL so it passes with little testing, but a twin turbo is considered to be more like a GTR so more requirments to get legal.
Edited by =premo=
Cheers
ok quincy,
If your heart is set on the r32 (i like the little gts 32 aswell) and alot of the other options are really adding up to big dollars maybe you might concider
stay with the rb20
buy gtr crank and rods $600 (bolt in fit)
Tomei forged rb24 pistons (i have heard 4g63 can be used but i have not confirmed this)$1500
Tomei cams 260 deg 8.8mm lash with cam wheels $1100
With the increased capacity and performance of the cams i think you could easily upgrade your turbo with any increases in lag (if tune right), just don't aim to big the turbo that seems to be around your size required and has produced 400rwhp on 2.4litre engine is the gt3071r $1695 you'll need external gate $400
you'll need gaskets, bearing etc (all the gear for full rebuild) ~$1000
but the bonus is at the end of the day you'll have a brand new motor 2.4 litres that doesn't require any alterations to fit like your other options and has forged internals great torque(has longer stroke than rb25) for your track work. The risk you run of buying a second upgrade motor is the condition is unknown and the life exspectance of it is unkown and eve.
Alot of the things sydneykid mentioned i would do regardless of the package you go for ie the direct electrical feed to fuel pump, z32 afm and fuel regulator etc
end of the day i think this would be your cheaper option and you'll have brand new motor that can really take more punishment than a std second replacement. I hope i may have just given you another option to consider for your upgrade.
pete
ps its just another option
A single turbo three liter twin cam is considered to be the same as a VL turbo and R32 gts-t has better brakes than a VL so it passes, but a twin turbo is considered to be more like a GTR so more requirments to get legal.
Which is roughly what I too was told by regency.
There's no real drama, but the problem is getting the emmissions test, it must also be run on the std ecu, which it does and can... Sure the stock ecu fuel cuts on boost but they don't test on boost so there's no problem there. :P
Hi, just wondering, if you were to add a complete RB25DE from an R32 to this scenario, what could you do to mix and match and produce a nice package?
Would you be able to create a nice RB25DET from the 2 engines combined considering that the Power FC, injectors and other bits are straight fit onto RB25DE from an R32.
QUOTE
Aren't rb20det and rb25det inlet manifolds a different bolt pattern?
I know rb20det and r32 rb25de are the same but I've been told an rb25det manifold won't bolt up to either.
quincy777
I had to make exactly the same decision as you.
My r32 had equivalent mods to your car but I wanted more.
I had planned to go the rb30/25det route but an r32 rb25de accidently came into my possession when I bought a halfcut for panels.
I realised I didn't need 300rwkw atm and decided to keep my 2530 and use it on the rb25 rebuilt with forgies and rb26 crank and rods.
I can always get a bigger turbo later if I feel the need.
Booster - did you rebuild the RB25de from R32?
I was also thinking of going RB25/30 but want to keep my Auto box, which means I'll also have to keep my 7500 RPM rev limit.
So now I'm thinking what can be done with the current RB20 setup together with a R32 RB25de I have sitting in the garage.
I'd be happy with reliable 220-230 rwkw.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
