They make bodykits out of mesh?
Fibreglass is cheap and light, but in most cases very brittle, after a while you'll get cracks and it will look like shit.
The OEM front bars are the strongest, because they bend, instead of cracking
FRP (fibreglass reinforced plastic) is what you should look for, but it's a lot more expensive than fibreglass, and usually only is available if you buy the original kit from japan
stock bumpers = polyurethane
of course fibreglass doesn't crack unless its been stressed...
but there's no doubt that its brittle.. even the stress of the chassis flexing when cornering over a long period of time can show on thin bumpers...
FRP sounds great.. anyone in oz make kits out of this??
you could probably get a kit made out of carbon fibre, but they would be weaker than glass.
a lot of mass produced glass kits are made really thin to save money, so they break easier.
the advantage of glass is that it can be repaired easy. i bought a front bar from a wreckers for $100 that was cracked down 1 side and it cost me $50 to fix it and repaint it (did it myself). the plastic kits cost a bit to get plastic welded, but they don't brake as easy to start with.
Personaly I love fiberglass kits as most aftermarket kits are fiberglass. I ve just finshed making a veilside kit fit a carmy 91 model (carby fed ) . It took 8 kilos of fiberglass but it looks very different .
Is anyone interented in seeing pictures?
why?
Well its not my job to ask why, it was brought to me and he asked me to make the modifications to make it fit to his car. I dont get to pick the cars i work on, its my job to fit the bodykit to it .
And also why not?
Im in the same boat and searching for a S15 kit perhaps the only way to get quality is to buy an origianal japanese kit ? im thinking about getting a kit from jetspeed or mxfly if all there kits are made of frp.
If this isnt a good idea feel free to pm a reason
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
