royal Posted August 2, 2006 Share Posted August 2, 2006 (edited) I would like to know what is the different between the auto and manual version of a R33 GTST, as i am looking at getting a auto (got offer a very good deal) and then converting to a manual! so apart from the gearbox is the diff / gear / computer different? also do they have differen spec in the engine? or use different computer? etc, so just anything else that you can think of! thanks guys .... any help will be very much appreicated! cheers Edited August 7, 2006 by royal Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/ Share on other sites More sharing options...
Freddy Kruger Posted August 3, 2006 Share Posted August 3, 2006 have you tried searching? I think the ecus are different as the computer has to handle the auto gear changes. not positive on that tho. then theres the usual interior stuff like gear surrounds, clutch, pedals etc etc Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2379274 Share on other sites More sharing options...
LBR33 Posted August 3, 2006 Share Posted August 3, 2006 Actually a auto computer can be used in a manual car but not the other way around Manual conversions can be found for 2.5k using a rb25 manual box and new HD organic clutch Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2379298 Share on other sites More sharing options...
12DFY Posted August 3, 2006 Share Posted August 3, 2006 Diff ratio's are also different. Still LSD and all, can get around this by calibrating your speedo. Everything else is exactly the same (apart form what was prviously stated about computer. Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2381001 Share on other sites More sharing options...
**JaR** Posted August 4, 2006 Share Posted August 4, 2006 yup. not a great deal of difference at all. Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2383731 Share on other sites More sharing options...
royal Posted August 7, 2006 Author Share Posted August 7, 2006 Thanz guys for the input! SO I would like to know more on the different in the DIFF!!! is this important/significant in terms of performance/strength??? Do they have the same final drive gear ratio? Cheers Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2389040 Share on other sites More sharing options...
dezz Posted August 7, 2006 Share Posted August 7, 2006 slight power difference from auto to manual as well 180kw vs 187kw ...auto-manual.. might be less of a difference in series 1's Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2389262 Share on other sites More sharing options...
smurf80 Posted August 8, 2006 Share Posted August 8, 2006 Where does it say that there is a power difference from auto to manual? I was under the impression that they all have the same flywheel figures regardless. Chris Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2390893 Share on other sites More sharing options...
SoFreshSoClean Posted August 8, 2006 Share Posted August 8, 2006 Nah he's right.. Auto's have 180kW/275Nm Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2391791 Share on other sites More sharing options...
dezz Posted August 8, 2006 Share Posted August 8, 2006 Where does it say that there is a power difference from auto to manual? I was under the impression that they all have the same flywheel figures regardless.Chris Nah he's right.. Auto's have 180kW/275Nm Yep, i've got it in an article somewhere... Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2391825 Share on other sites More sharing options...
smurf80 Posted August 8, 2006 Share Posted August 8, 2006 There ya go learn something new everyday. Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2391960 Share on other sites More sharing options...
WazR32GTSt Posted August 8, 2006 Share Posted August 8, 2006 sure? i thought power levels were the same obviously it would have less at the wheels due to extra drivetrain losses.. i want proof... Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2392428 Share on other sites More sharing options...
dezz Posted August 8, 2006 Share Posted August 8, 2006 sure?i thought power levels were the same obviously it would have less at the wheels due to extra drivetrain losses.. i want proof... well i cant find the articles i have no reason to lie about it... the article was all about s1's, probably back when they were still new-ish...auto 180kw, manual (whats a series 1 engine put out? 184-185kw?) Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2392472 Share on other sites More sharing options...
Modena Posted August 8, 2006 Share Posted August 8, 2006 well i cant find the articlesi have no reason to lie about it... the article was all about s1's, probably back when they were still new-ish...auto 180kw, manual (whats a series 1 engine put out? 184-185kw?) Is it the same for S2s? Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2392651 Share on other sites More sharing options...
dezz Posted August 8, 2006 Share Posted August 8, 2006 Is it the same for S2s? id assume so... Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2392652 Share on other sites More sharing options...
SoFreshSoClean Posted August 8, 2006 Share Posted August 8, 2006 http://english.auto.vl.ru/catalog/nissan/s...e/1996_1/21674/ 'S all here Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2393433 Share on other sites More sharing options...
Modena Posted August 8, 2006 Share Posted August 8, 2006 http://english.auto.vl.ru/catalog/nissan/s...e/1996_1/21674/'S all here Says the manual is: 183.88 kw / 6400 rpm 294.20 N*m / 4800 rpm Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2393868 Share on other sites More sharing options...
2rismo Posted August 8, 2006 Share Posted August 8, 2006 I believe the diff ratios are: Auto - 4.3:1 Manual - 4.1:1 Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2393917 Share on other sites More sharing options...
dezz Posted August 9, 2006 Share Posted August 9, 2006 Says the manual is:183.88 kw / 6400 rpm 294.20 N*m / 4800 rpm makes sense..pretty sure series 1's are 184kw and series 2 are 187 (manual) Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2394264 Share on other sites More sharing options...
LBR33 Posted August 9, 2006 Share Posted August 9, 2006 Keep in mind people not every r33 skyline will make the same power they will vary 5-10% either way of their rated figure Link to comment https://www.sau.com.au/forums/topic/128558-diff-different-between-auto-and-manual-r33/#findComment-2394300 Share on other sites More sharing options...
