Ok I found the article...
here's the paragraph, quoted word for word
"The automatic version actually has a very good four-speed electronically controlled transmission too, but it would be a shame to lose the fun of that brilliant five speeder. The automatic versions made only 180kw and 274Nm of torque (compared to 184 and 294Nm for the manual), which combined with an extra 20kg kerb mass makes them substantially slower." - Ben Ellis (High Performance Imports)
I'm also interested in this because I have an auto 4-door. I was planning to sell, but I'll lose money and I love the car.
So basically for a tranny swap you'd need
RB25 gearbox
Pedal Box
Interior stuff (gearstick and plastic cover thing)
And labour would inlude fitting and recalibrating the speedo.
Right???
I wouldnt take HPI as gospel as Ive read from time to time when they compare cars the power torque figures and quarter mile times vary from different issues. Iwas under the impression series 1 & series 2 R33's made the same power at the flywheel (manual) it was just the series 2 gave back a better power at the wheels result due to them being younger. This is in stock form of course.
For example:
In issue 23 they did the comparison of a 1994 4 door 33 automatic vs a AU XR8 and the power & torque figures were 185kw & 295nm They claimed the 33 automatic did the quarter mile in 14.9 secs ....But
In issue 48 they compared a 1995 R33 gtst manual vs a 1993 300zx and it they quoted a power and torque figure of 187kw & 295nm. They claimed this 33 manual did the quarter mile in 15.2 secs
Then there is your quote Dezz from im guessing an earlier issue of HPI so whats accurate??
Chris
Edited by alphanumeric
i done a manual conversion at the begining of the year, you will need
clutch/brake peddles
master and slave clutch clyinders
clutch plus spigot and flywheel
tailshaft
gearbox
shifter
manual instrument cluster
manual spinny thingy at end of speedo cable to go into manual gearbox
centre consol where gear stick comes out of
inner and outer gearstick boots.
got the safc2 tuned to the manual
started with 215rwhp, went to 256rwhp with gearbox and fmic only.
thinkn about changing the diff soon too as speedo is a little bit out and 1st revs out a little to quick
i think thats about all
cost me just over $4700 to get a workshop to do the work.
not a cheap project anymore due to lack of part in australia.
hope this helps
  • 3 weeks later...
Thanks everyone for the input!
This topic is being very information!
I got a question in regards to the diff ratio:
so with a 4.3:1 diff in the auto... and after converting the box to manual and left the diff untouch will mean that it should thoretically accelerate faster than the Std manual R33,.... is that right?
I'd like to know too,
I'm doing the same conversion with my 4dr trying to decide whether to buy a new diff to get the manual gear ratio.
Also does anyone know if the auto diff is a 1/2 by 1/2 way? Is it worth converting to a 1 and a 1/2 way?
Can you buy the internals or do you have to buy a whole new diff?
i also would like to know about the diff, do i need to change the diff if i convert from auto to manual?
does the car drive the same as any other manual r33(Better or worse) or is there any problems with the conversion that effects the car)
thanks to any1 that can help :huh:
had the conversion for a little while now. have had no problems as such. need to get the clutch ajusted as operating at top of peddle and needs to be moved down (getting done next week). miss the auto sometimes but i wouldnt go back. as i said a couple of posts back, the engine revs out a bit quicker than i would like, but this could be a good thing. the speedo is very slightly out (when doing 60 on the speedo im actually doing 58), this will multiply when going faster obviously). also, i would recommend getting it licenced as a manual, cost about 35 bux to go over the pits. they only look at the conversion but will need to write down size of your wheels so put stockies on if they are over 7" wide. hope this helps
Get them to increase your freeplay on your clutch.
Revving quicker is a good thing, gives you ability to change gears quicker as the revs drop faster.
So I should do a manual licensing thing? What benefits come from this? Is this done by the RTA?
  • 2 months later...
Digging up an old thread, but i have had the conversion done
everything is going great,
only thing i have been querying, is the auto diff is still in the car
i have noticed, and found out from this thread, because of the different gear ratios,
that my car is sitting on 2800rpm on 100 and is f@#kin annoyin me.
so i will be after a manual diff, or jsut go aftermarket and get a 1.5way
is this a good option?
im wantin to drift my car, so would best option just to go straight for a 1.5way. Im still using the car for the weekend.
Does anyone know the cost involved in gettin a new diff put in, and how long it takes.
Thanks
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
