My mates RB20det Laurel is has been miss firing worse and worse for the last 3 weeks+. Now it won't start. We suspect it is the ignitor or associated wiring.
The igniotor was sitting unsecured, roasting on the cam covers, as the coil pack cover was removed.
Is there a way to test the ignitor pack with a multi-meter? And is it likely he has caused terminal damage using the car weeks after the miss firing started?
Going to try get onto this tomorrow. Any input appreciated :P
Cheers.
https://www.sau.com.au/forums/topic/128559-ignitor-pack-testing/
Cheers buddy but I actually mean the black box that sits on top of the coil pack cover.
I tested the coil packs on this car a month ago. Had to replace one with an R32 tpe pack as it's all I could find. (C33 etc are different to R32).y
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
