lol no but ur brothers an idiot... anyone who listens to anything that he says is as bigger idiot :D to him a VL is the fastest car on earth cause his stock 33 got eaten by one lol
  • Replies 91
iprimus sucks much c*ck... but then again... its no worse tel$tra n potus.
At home I use pacific internet and its sweet as (10gig download cap)next week i might be buying a Netcomm 1300 Ethernet/USB DSL Modem with inbuilt router... wheeeeeeeee dawgy...
Ah well as long as primus pays my bills das all i care about.
they all suck the d#ck...
but they pay my bills so all is fine by me :D
Netcomm 1300... lol beter not try reseting to the factory defaults... unless u want a dead modem.
damn, im on optus cable capped 3 gig :D:( once over capped on 28.8 k modem which im on right now :D:( thats why im not on SAU as much as it takes bloody agesss just to post this!!..
You guys know any good broadband connection? good prices too.
I saw TPG $69.95 a month with unlimited d/l and u/l, but its capped to 256/128.. still , anything with unlimited would be good so i can leech away.. :)
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
