lol no but ur brothers an idiot... anyone who listens to anything that he says is as bigger idiot :D to him a VL is the fastest car on earth cause his stock 33 got eaten by one lol
  • Replies 91
iprimus sucks much c*ck... but then again... its no worse tel$tra n potus.
At home I use pacific internet and its sweet as (10gig download cap)next week i might be buying a Netcomm 1300 Ethernet/USB DSL Modem with inbuilt router... wheeeeeeeee dawgy...
Ah well as long as primus pays my bills das all i care about.
they all suck the d#ck...
but they pay my bills so all is fine by me :D
Netcomm 1300... lol beter not try reseting to the factory defaults... unless u want a dead modem.
damn, im on optus cable capped 3 gig :D:( once over capped on 28.8 k modem which im on right now :D:( thats why im not on SAU as much as it takes bloody agesss just to post this!!..
You guys know any good broadband connection? good prices too.
I saw TPG $69.95 a month with unlimited d/l and u/l, but its capped to 256/128.. still , anything with unlimited would be good so i can leech away.. :)
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
