Hey all - am after a bit of advice here..
Am going to be undertaking the task of helping Zanda to change a set of exhaust manifold gaskets on a newly imported R33. It's a 95 (I think) and hasn't done a huge amount of kms.. somewhere around 80,000.
Any ideas of what problems may be faced? My plan of attack is as follows:
1. Take off all piping to turbo
2. Remove exhaust from turbo
3. Unbolt exhaust manifold from engine block
4. Replace gasket and bolt up again with new bolts
5. Replace all other bits..
I think the main problem we could face is that we won't be able to move the turbo because there will be no flexible lines attached to it, only fixed ones.. So we'd have to remove the turbo..
Any advice - however trivial - will be very much welcomed...
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/
Caminperth,
Besides all the heat shields and gear that hangs off it, you will have to disconnect the oil line to the turbo, there is not much oil loss here. You can leave the turbo on the mainifold but if you dont you will need a new turbo to dump pipe gaskets and manifold to turbo gasket. To make things easier, it will need you to undo the exhaust just before the cat, so the fornt pipe can be free, it is just easier to have this undone. When you change the engine to manifold gasket make sure that it is one piece and not the 'VL" six individual piece setup. These single piece setups seems to 'blow out' on a regualar basis. One other problem you might encounter is the manifold bolts, these might break and I would be amazed if you dont break at least one or two on a donk that has done 80K's, it just the bolts have cystalised and become bittle over time. Have a welder on hand to weld a nut to the broken end and undo it this way, if it snaps again have a helicoil kit on standby to deal with this problem.
Anyway, best of luck my people might give you other ideas here, Im just giving you my experience on this subject.
Have fun:)
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-240203
leave the turbo attached to the manifold, you dont have to lift it all up just across toward the strut. i did this a couple of weekends ago with no real dramas, other than i couldnt get the thing out but that cos its a hks setup which hits the chassis rails
ive heard as little as 2hrs for the job so i reckon you could do it yourself, its just a matter of unbolting and being methodical so you dont lose anything or drop any bolts into the manifold!
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-240225
Thanks all for the advice - from previous experience on my rb30 engine in my VL I know exactly how brittle these bolts can/will be.. and I'm quite scared.. it adds a whole new dimension, adding helicoils, using a welder and things like that.. not sure if Zanda will be too keen about letting me loose on it anymore.. ;)
Will have to see what $$ it's worth to get done. Sometimes it's better to employ someone else to do the work.
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-240401
I've just found out that it's the manifold/turbo gasket NOT the manifold/block gasket. Hopefully will be a hell of alot easier. Am going to drop off the turbo tonight.
Thanks again for the advice guys. Muchly appreciated.
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-240438
That's right.. and DON'T get to eager in twisting the bolts completely off... I did that to mine recently...
Thank god i had got boost and bully to help me :D (p.s. sean, i still owe you some JB's :starwars: )
I successfully broke TWO bolts (which are still in my block, the first and last ones!) and it's fine.....
... still yet to get time to easy-out them ;) i'll get there one day...
and tips: DON'T lay underneath the front pipe when your mates are pulling off the turbo! *smack!*
hehehe
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-242005
Bully, Got Boost & Strich9ine - will definitely be using a few cans of crc and some beer drinking/soaking in crc time before tackling the bolts to the turbo. Luckily from all info gathered - it should be a relatively easy job to losen off the turbo, slip in the gasket and tighten them up again..
There will be NO heavy-handedness with these I can assure you! ;)
Thanks again for the info - muchly appreciated..
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-242104
righto - update..
Got to the turbo (finally!) after pulling off all the piping & shite above it. After removing the heat shield - hey presto - there's the flange and it's four, oops, I mean 3?! nuts holding the turbo onto the manifold. These things have tab washers to lock the nuts in place and it wasn't bent back - how the hell did one of the nuts come off?!? The other 3 were finger tight too!?
So anyways, got the 3 nuts off and moved the turbo back a bit and DOH! A bit of the gasket falls into the turbo. Looks like the whole thing is comming off to remove this - though hopefully I can just get to the bit of gasket with some pliers or something.
So some more questions - how tight should the nuts be? That is, the one's holding the turbo to the manifold. Is there anything I could've forgotten to do that will cause the car terminal damage?
Hopefully putting it back together will be a straightforward and easy job for Saturday night.
Any advice/criticism/shit giving welcome. :D
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-243828
Originally posted by zanda
doh!
cam quote of the day:
"hey, look..you can see where its all cracked and ****ed up, no wonder its leaking......see, just there"
*points. prods*
"binga-ding"
*censored*
Hey - feck off.. :D
We don't have to pull the manifold off - just drop off the oil supply hose and take the bolts out between the front pipe and the cat and we should be able to get to it.. trust me.. :) hehehe...
https://www.sau.com.au/forums/topic/12857-exhaust-gaskets/#findComment-244222
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
