There you go, EXACTLY what happened to mine, after 90,000kms I don't blame it.
My nuts were finger-tight too, but i DID have at least 4!!
Cam, we didnt need to undo the oil/water supply lines to get the gasket off hey :D We just loosened the front pipe and used goon-strength to pull it "off" the four studs holding it onto the manifold.
In my endevours I rounded off 2 heatshield nuts (nowhere to mount my EGO sensor bracket now, so it's cable-tied up!) and 2 Manifold bolts. ugh!
'Spose you couldn't have done any worse!
Stric - hmm - me thinking I'll be checking mine - or getting them checked when the dump pipe goes on..
As for the goon like strength - can supply that easily enough (me not smart, can lift heavy stuff but! :D ) - though was hesistant to do that because the turbo seemed to be constrained in it's moment by the hard piped oil line underneath. In other words, I'd rather romove it than chance breaking - Zanda would never let me hear the end of it.. :)
got an update on the novice backyard mechanics for anyone who's interested...
spent the weekend grunting and groaning, trying to remove the coolant lines and the two bolts holding the front pipe to the cat. all of them were fu:) ) we were able to undo the coolant lines and remove the oil lines from the turbo. with all of these lines off and the manifold bolts off - the only thing left holding the turbo in place was the cat/front pipe bolts... no problem.. yea right!
those mothers were waaaay rusted! i recommend anyone who is deciding to do this carry a BIG can of wd40 and a BIG spanner - possibly even a hammer! after much bashing, got one bolt loose and out and the other one snapped cause the thread was so rusted...
while the lot is out - it was decided that a dump pipe should be added before putting everything back...
so - things left to do..
drill out bolt in cat
fix heat wrap around air con lines (damaged when pulling turbo out)
re-attach oil/coolant lines to turbo
replace turbo/manifold gasket (the original job!)
replace all piping
check oil/coolant levels and top up accordingly
give offerings to local god.. start engine.. :P
btw,
thanks to adam32, who offerred his saturday evening input.
as it turned out, the fiasco was justified. Although I speak for myself, I felt much better about spending all that time rolling around on the ground once the piece of rogue gasket turned out to be one inch long.
blade chewage averted.
  • 1 year later...
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
