Z32 Afm Pod?
Will be installing a z32 afm onto my r33 shortly and needing to know will the pod of the stock afm fit the z32 or will i have to purchase a new pod to suit the z32?
If have to purchase a new pod will buy the apexi power intake. does anyone know what the product code is for this?
Edited by bygrave316
Yes.. the Z32 is the same size as the std afm.
It simply has a different airflow vs voltage output calibration.
Thanks for that Cubes,
Thinnking about buying a new filter anyway.... got a blitz filter on the car atm but i hear that they might not do that good a job and that the apexi's are about as good as they come is this true?
I like the apexi, coz they look nice.
There's a few others that are also good, ??pipercross?? comes to mind for some reason, SK could clear this up as he has mentioned them in the past.
In some dirt hoover test the apexi came out on top for filtration.
Looking at nengun and there are to differnt apexi filter kits? whats the difference?
ones called APEXi - Power Intake kit and costs arount 110 deliverd and the other is called APEXi - Dual Funnel Air Cleaner (Replacement Filter) and cosrs around 80 dilivered is there something special about the Power Intake kit?
i've got a stooooopid question, but i still need to ask it.
what's the benefit of the z32 afm on an r33?
Hence will read more air at 5.1v. So you can tune to a higher power level before maxing out the airflow meter.
one (Power Intake kit) comes with the small metal adapter that says apexi on it...
the other (Replacement Filter) is simply the filter part that still bolts onto the AFM if you get the correct one...
ok thanks so there isnt any difference basicly apart from gettting a bit of metal.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
