Hey Guys, I understand this has been covered and believe me I have searched but anything I find, the link is no longer availible...
I want to install my Tomei Hicas lock kit this weekend but the instructions are in ne hon go...
Can someone please point me in the right direction to find english instructions or wiring diagram?
Thanks for your help!!
Todd
https://www.sau.com.au/forums/topic/128604-tomei-hicas-lock-kit/
cool.
this is rhe procedure..
start the engine and WITHIN TEN SECONDS!! turn the steering wheel 1/2 turn LEFT hten RIGHT 5 times then depress the brake pedal 5 times.
this will put hicas into a diagnostic mode.(dont drive it)
it will take a few gos to get it. its hard to do all that whithin 10 seconds lol
when its inttalised the hicass light will flash. turn the wheel left and right asnd you can see the rear turn. use this procedure for inserting the shims into the rear steering rack(they wont fit otherwise)
as far as the electrics go ??????
Thankyou VERY MUCH! This should be in the DIY/FAQ section!
^I think copyright prohibits this.^
Can someone translate this for me? Please Phunky?
As the r33 plug looks nothing like the one shown on the PDF doc, Im having trouble choosing which wires to plug into.
I fitted the lock washers last night, I used a 12v source to move the rack (those screw are sooo tiny) and wheel aligned today, the light is on but it drives like a normal car with none of that tail waggle that I had to get used to when I first drove it, I prefer it like this and when/if I ever get the wiring colour codes, I will get rid of the light, I want it working as hicas also governs the power steer and hopefully it still comes on if there is a problem (touch wood).
Well after much searching I found this on a site.
I am guessing that the signal wires A & B are the wires on the rack that read the movement of the rack, without running out and looking, i know there are 3 wires on that connector, I can get an idea of which is which, I will have a look at it tommorrow and see what happens.
I did it! The pic is a wiring diag of the setup for a R33.
Thanks to all who helped with this Al, Predator, Shane, ColGTSX, Bl4cK32, Sav man and anyone else that I Pmed :rolleyes:
Disclaimer: This worked for me it is no guarentee that it will work for anyone else.
  • 4 weeks later...
hey guys
i went with the above post picture
and i got a 96 r33 series 2
i went with the wire harness guide and installed it as pinned out on the harness but either way i look at my harness in the middle section those wires indicated arent on there
in the first picture i have showed the wire which i have spliced into
the second picture is looking at it from other side also indicating how i have wired it
cheers much help is need before my care is running as i dont wanna ruin anything
cheers
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
