Im sure there must be a reasonable explanation, but why is it that my stock manifold has a water feed. My old alfa had a heated intake for fuel economy, but we go to lengths to cool the intake charge then have it heated by the plenum?
https://www.sau.com.au/forums/topic/128625-why-is-my-intake-manifold-heated/
below zero climates could seriously stuff with your engine and its mechanical workings....for eg if you lived in japan and parked your skyline outside during winter :laugh: Same as the heater/cooler on the oil filter.
I thought it might be for emissions, but for a cold start up I thought the thermostat restricted water flowing untill the engine was warm anyway?
So could I use a brass T' piece to divert the flow from the head?...
-Might have to try that in summer, its still too cold in Tas (sympathy please :laugh: )
Edited by Medium Dave
Rob is on the money. When you have a shower of a morning, the steam condenses on the mirror. If the manifold is cold the same thing happens with fuel, it condenses on the inlet manifold, giving you a lean mixture which isnt conducive to smooth running with a cold engine.
no do not divert the water away from the head.
the head must always flow water.
You block each end of the inlet/outlet jacket to the plenum so its bypassed. This is easy on An RB30
I cant comment on the twincam stuff.
note! you will Have ruff start up if you live in cold areas....
That's what you do and what the negative is... what is the positive??
the water feed to teh turbo comes from the plenum .
if you are talking about the line that runs next to the injectors??? it comes out of the rear of the plenum around the back of the head and to the turbo... i wouldnt be blocking this off :blush:
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
