Firstly oil temp. I am rewiring a bunch of meters, and i always thought you wanted to measure the temp of oil in the sump. So in my case i would place the temp sensor after the oil cooler, so i get an idea of the temp of oil the engine is about to ingest.
Now a friend was sayign recently that his mechanic had it on the oil line to the cooler so you read the temp of the oil coming out of the engine.
So anyones thoughts on who is right or why they plumb theirs a certain way.
Also with the oil pressure sensor, does anyone know the thread size? I was going to plun my new VDO sensor in the location of the std sensor. Can you just run a t-piece in the oil cooler lines??? Doenst seem ideal but would make life easier during the insall
you measure water temp after it leaves the engine ....
i would think the same applies to oil temps
but then again, nearly everyone says sump to me aswell. other than people who have the sandwich plates and they just use them without knowing whether its in or out feed
Not sure with piston engines but I know with turbine engines the sensor is generally on the scavenge side of the system, so between engine out and the cooler, it's said this indicates failure more quickly. Makes sense to me that it would work the same way with cars.....
Measuring from a t-piece isn't the best solution as this creates a restriction in the flow, better if you can use an inline sensor.....
Well i will probably end up just teeing into the std location and running some 1/8" tube or something to the inner guard where i will mount it.
The vibration is meant to hurt then if you mount them direct to the engine hence my wanting to use a tpiece into the cooler line...also helps with access
i just mounted the sensors for my defi gauges (oil pres, oil temp) both into the side of the greddy remote filter mount.
on the afla we run a line (braided) from the standard location up to a little 'bar' which is milled from a billet. it has a hole in each end (one is blocked, one has the feed) then 3 holes in the top. One has pressure sensor, one temp, one warning buzzer sensor. It is basically a little fuel rail. very neat way to do it, and it means we can mount it on the firewall so the wiring is away from all the hot stuff. and it's all easy to access.
wouldn't the temp one lag with this not being a flow through type setup ??
once the line is primed wouldnt the oil that is there to start with not be removed from its place if its pressurised ?? hence taking a long time to heat up since it isnt passing through the engine.
just thinking of the path of least resistance..
  • 3 weeks later...
in addition to the above, can anyone help me out regarding the method of changing the oil pressure sender on an R33?
I have the new sender and can see where the plug goes into the old one, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
(apologies for posting in 2 sections, need an answer asap)
nah, the oil is definately flowing through there. oil temp is responsive enough, oil pressure is really responsive too. it's amazing how much faster it works than the stock gauge, though at a constant reading their values are very close.
tommo, are you sure oil pressure guage is a RWC requirement? most cars dont even have one.
sorry, it's not the actual guage, he sighted "oil around oil pressure switch (sender)", possibly from me spilling a little oil when changing the filter last. only item on his list other than stock airbox ;)
thought fair enough, rang up bursons and got the part, but now the mechanic is too busy to fit it this arvo.
buyer is flying in tonight and driving back to the ACT, so i'm kinda in a bit of a hurry
Edited by thommo
I'm about to do what Beer Baron did, was going to tap it into the sump but the guys at Motorsport Connections said that a t to a remote location on the chasis is fine and very common
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
