would the apexi exhaust control valve work with the blitz nur spec exhaust cat back or only for apexi products?
ive emailed nengun about my concern...but just thought id get an opinion from my fellow skyliners :P
info can be found here about the ECV
http://www.nengun.com/catalogue/product/239
https://www.sau.com.au/forums/topic/128643-apexi-exhaust-control-valve/
you'd be better off just putting a silencer in the rear, like what most systems come with. no cutting, and much cheaper.
thats what i was thinking but for some reason the blitz nur spec dosnt come with one...at least the one im buying....
do i have to call blitz "japan"
and if i do get a silencer.....how much would it restrict my power?
hrmmmm.....maybe im better off getting a different cat back.....any suggestions?
i know of the HKS Silent HiPower one.....but i like a deep sounding note to my exhausts....how silent is the hks one?
Edited by anDru
I had the same exhuast, it still failed EPA with the silencer in by 2db... i had to install another resinator into the system either that or install a mid muffler.
By installing the silencer your car will aslo stop making power at a certain rwkw like mine did..
man thats shiet........do u still have the thing isntalled? what is the legal amount of db we can have...and how much is the blitz nur spec without restrictions?
Edited by anDru
noise and restriction are proportionate. I don't care what anyone says about their quiet system that doesn't cause a restriction.
Basically, it will be more restrictive if you make it quieter. The question is HOW MUCH that restriction affects your GIVEN POWER OUTPUT.
Personally, I run a straight 3" pipe. Most possible power, minimum possible restriction.
BTW, I have an ecv in my car. It's very restrictive. The car feels like it accelerates about half as fast. you can watch the revs climb if you stamp it, and it is really choking. Whereas, in first, if I normally floor it, the rev needle just smacks straight up to the red.
Regarding the rear plug in silencer (buttplug), i find mine to be quite restrictive like the ecv.
Regarding the centre muffler - refer to my first point regarding noise and restriction.
btw, ecv is not 200
firstly, it's 300$. you need the 81mm version if you have a 3" exhaust.
Then you need an exhaust shop to cut off one of your flanges, then weld in the ecv.
It's u to you whether you want to quieten it down. personally, i want it as loud as possible.
Why do you want the Blitz?
The Trust Power Extreme II is very quiet but still gives off an awesome growl when you give it to it. I believe it is also 88dB alone (stock dump + front pipe) as well, so all legal. (Info from Trust site)
Edited by ToF
Dont waste your time with the apexi evc i hav it and had nothing but problems with it so its now wired fully open.. spend the extra cash and get yourself a legal exhaust system.. best iv seen are CES exhaust systems in brisbane.. they will hav a system in stock to suit your car and guarentee legal db's and 20+kw gain...
well blitz is the only one ive herd from ppl with a very nice sound. if the trust power extememe 2 is as good as u say id be more then happi to get one.
thanks for ur input guys......i guess the ECV is out
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
