Hi,
Im looking at buying a dump pipe and front pipe for my RB20DET. Im running a R34 turbo and was wondering which system would be best. I can either get the seperate dump and front pipe or the the dump pipe and front pipe in one. Buying them seperate is alot more expensive but I was wondering if it would be worth it? I was also wondering how much the boost will raise once i put the dump pipe on?
Thanks
Matt
https://www.sau.com.au/forums/topic/128668-dump-pipe-front-pipe/
Check out BATMBL on this forum. His stuff is good, with split dump/front pipes available. But i'm not sure how you will go with havig an R34 turbo on an RB20, you might have to make some modifications.
Mate just go the front and dump pipe in one because you won't need a screamer pipe (the one sold seperate) unless you are shooting for/have crazy horsepower...plus they are illegal and you will cop a massive fine and a nice yellow canary for the screamer.
I am getting the 2 together and they say you can raise it by about 2-4 psi but I would still be cautious if you don't have a FMIC or anything else...
Sorry mate, thought I could be wrong, but have been told by a mechanic that that was a screamer...might not go to that mechanic again then hey...
However, frost is right you would need to get a front pipe fabricated and would probable cost a fair bit
Screamer is when the wastegate gasses are dumped straight to the atmosphere (ie the wastegate pipe doesnt plumb back in)
I would buy one of BATMBL's split pipes. He has a group buy running at the moment so just get one of those. If the R34 turbo bolted up to the stock R32 dump, then I'd say BATMBL's dump/front pipe should work ok (check with him first)
Hi,
Thanks
Matt
The first one is certainly your best choice out of the two displayed. The separation of the pipes in the second one is not long enough this will cause too much turbulence where the pipes meet. Split dumps are good but there needs to be at least 30cm of separation before the pipes join.
The BATMBL split dump/front pipe would be a better option than the two displayed.
Cheers
Thanks guys,
Yeah I will get the Dump pipe and Front pipe in 1. Hopefully I will get a 2psi boost or more. Will the standard CAT be a problem? I wanna get a hi-flow but cant afford it at the moment, any cheap way of making my standard one hi flow? Im running 10psi at the moment which is standard. Will the boost be stable when running at 12psi or more? or should i put on my boost controller? (Turbotech Manual Boost controller).
Im running:
FMIC
R34 Turbo
K&N Air Filter
3 and a half inch form cat back
Lighten Flywheel
Extreme Clutch
Thanks
lol... well you have a few defectable items there already, so in theory you could just completely remove all the honeycomb from the cat, but it's illegal and I wouldn't suggest it for an onroad car.
Better off saving for an xforce 3" large body cat. They're about $300 from JustJap, and have the cat sensor thread in them already.
but the fine for a hollow cat is a few thousand dollars more than the fine for the rest of the defects. i got my x-force cat for $175 off ebay. and i agree with kennedy that a highflow cat will give a bigger power gain than a front/dump pipe if the stock cat is still there.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
