From: http://www.expressadvocate.com.au/article/.../1503_news.html
POLICE plan a $750,000 blitz on speeding on the Pacific Highway after a weekend in which motorcyclists turned it into a ``race track''.
In one instance police had to give up pursuit of three bike riders after they hit speeds of 250km/h.
Brisbane Water highway patrol sergeant Gary Carr said police recently obtained $750,000 to fund round-the-clock patrolling of the highway between Mooney Mooney and Kariong during busy periods.
https://www.sau.com.au/forums/topic/128673-old-pac-targetted-again-by-the-cops/
How come the paper was talking to Brisbane water police about a NSW Highway :laugh:
Brisbane Water is both Gosford & Woy Woy on the Central Coast, Command Centre for the F3 Highway Patrol. I've seen many cops around Mount White on weekends (especially early Sunday mornings for some reason) targeting bikes both ways where the road divides near mount white.
A group of guys (known as Midnight Run Club I think - drive VERY FAST!!! midnight runs on the old pac during weeknights) recently were targeted with an operation at the bottom of Mooney Mooney. Multiple cops and camera's - People lost licences & cars were impounded. They stopped when police were regularly there.
Just make sure you make a recon run first! Plenty of other great roads in the Peats Ridge and Mangrove Mountain areas anyway.
You speed on that road...you will get caught. It's only a matter of time... but looks like sooner rather than later with this operation.
The speed limit on that road is not overly slow either for the corners that are there.. plenty fast enough to still enjoy the drive!
even if u are going the speed limit down that road if u are driving something interesting good luck not getting pulled over and lectured at the least.
Overly is still too slow though sometimes though; even seen yourself "try" to keep up with a s2 R33 & HSV Ute on that exact stretch of roads not exactly keeping to any speed limit.
RECON FIRST!
copy that 10-4 :D
well, if the old road gets too much of a hassle - ill just use galston gorge - 2mins from my front door :P
Love the three lane hill climb from Brooklyn to Cowan - Fast sweeping corners, plenty of room, most corners are on camber so easy to control slides - should just spend evenings timing runs up and down - Posting best times behind one of the road signs. Cops aren't targeting it either.
Whens the East Coast Targa this year, are they still closing it off for racing?
Edited by Gun Metal Grave
burnsie - round the clock....to me means 24/7 :P
gun metal - apparently the dutton rally is meant to be doing it in november - december this year
and that hill climb rocks.... :D
Oh the ironing!
Everyone knows that this stretch of road has been heavily patrolled at different times for many many years, and those that still choose to enjoy a spirited drive in that area do so at their own risk.
Scathing, I guess the Police think its time to crack down on those people that over estimate their abilities and push themselves and their cars just that little bit too far.
Considering the massive number of serious and fatal accidents on that road, the majority of which involve either a performance car or a motorcycle, I am not surprised that Police are stepping up their efforts to try and do something about it.
hahaha mooney mooney - you might know some people I know :P hahaha (went to my school)
burnsie - read it again :(
"obtained $750,000 to fund round-the-clock patrolling of the highway between Mooney Mooney and Kariong during busy periods.
This may involve speed traps set up permanently over weekends."
round the clock :(
im still not going to risk it mate - you can :D
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
