guys im thinking intercoolers here, and im going do buy a hybrid (or similar) core, and want to get custom piping made up which is a copy of the more expensive brands (trust, blitz etc) so remove the need to any major cuts to my front bar...
just wondering what ppl think of this idea and any places to recommend getting the piping done?
james
https://www.sau.com.au/forums/topic/128674-custome-piping/
What car, what bar? Ring around. By the time you pay someone to measure, cut, weld, polish/paint and isntall...the off the shelf kits are cheap.
Unless you do it all yourself and have afriend that can weld, or throw a case of beer to a guy on the side to weld it up after hours...the Jap kits a re quality products at a good price.
https://www.sau.com.au/forums/topic/128674-custome-piping/#findComment-2379195
Dont know. they could be better, could be worse. Even if they look good, doesnt mean they are good. Ppl quute flow figures. Buit coolers are there to cool so they shoudl bloody quote effeciency figures or kws cooling. Sure they need to flow well, but there is no point hacing a cooler that flows well but deosnt cool.
Thats what i have heard about the cheap cooler, flwo well but dont cool well.
Good quality parts are worth the money as they work well and last. They dont have to be Jap, but i doubt a $199 cooler will get good results. But would be interested to see some tests of a cheap cooler.
https://www.sau.com.au/forums/topic/128674-custome-piping/#findComment-2379242
also, the end tanks on the cross flow kits (arc and blitz LM) are completely different to turn flow kits....they face the other way, and then its a straight pipe off them....not a bent pipe coming out of the end tank ....just letting you know
and some people have paid like $900 for custom piping....+200ish for a cheap core...thats arc,blitz money already...
https://www.sau.com.au/forums/topic/128674-custome-piping/#findComment-2379364
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
