Howdy all,
Just thought I would share my joy at seeing/hearing my motor up an running for the first time in 10 weeks. Its just about finished (little bits to go on) and should have it back this weekend - YAY!
1000kms of running in and then another 3000 of gentle driving and we'll see how it copes with 18-19psi. Will keep you updated and hopefully have a dyno sheet in a few weeks.
Cheers,
ken
https://www.sau.com.au/forums/topic/128684-its-aalllliiivvveee/
Yep, full rebuild. Here is the list
Block and head acid washed and decked, mild head port
Gen nissan rebuilt bottom end (just as good as aftermaket apparently)
REV I beam forged rods
CP forged pistons
Tomei sump kit
N1 oil pump
N1 water pump
Tomei enigne gasket kit
Tomei 260 cams
OS Giken cam gears
Greddy timing belt
Bling clear camgear cover (couldnt help myself)
D1 Splitfire coils
Sard 720cc injectors
Greddy fuel rail
Bosch fuel pump
Malpassi RR reg
Remote oil filter and cooler
40mm triple core radiator
102mm Blitz front mount
Z32 afms
N1 Group A turbos
Tunagent exhaust mainfolds
HKS dumps
Nismo front pipe
Trust PE2 cat back
Autech oil air sep
Couple of guages
Power FC with HC
Greddy profec spec2 ebc
Pretty sure thats it.
Its going to be really frustrating running the thing in. Might have to set the pfc for low rpm and "lose" the hand controller for a while, aarrgghhh.
Edited by RBNT
hahahhaa 4sure!
there are so many variables with running in engines - maybe talk to Cruisliner or Sydneykid about it?
thats a fair sized list there.......... well done and best of luck.
have a read: http://www.mototuneusa.com/break_in_secrets.htm (warning: for bike engines!)
Advice lads on running in? Much appreciated. This is the first motor I have had to rebuild, I'm pretty surprised it didnt happen sooner. Hopefully never have to do it again either! Bloddy expensive.
Well done on getting it finished, it's such a great felling to hear it burst into life the first time. :P
I have used the same basic running in process for lots of years and on many engines;
Castrol GTX (the basic no frills mineral oil) with new filter.
Run engine for about 1/2 hr or until well warm.
Change oil filter. Engines can have particles in them that acccumulate during the build/maching proces and they need to be removed from the engine ASAP, these are caught in the oil filter. If you leave them in, the oil filter can get blocked and so it will be bypassed ie; no filtering.
Check the basic tune on the dyno or on the road with portable lambda sensor.
Drive to Bathurst and back, around 500k's, lots of varying conditions, up and down hills, freeway, long climbs etc. Don't rev the beegeesus out of it, gentle but firm, change throttle openings often, no slogging it in high gears with lots of throttle. Much better to load it up with partial throttle openings going up hills.
Drain the GTX and remove the oil filter.
Refill with Castrol Edge 10W60 and fit a new oil filter.
Do leak down test, if OK then final tune on the dyno.
Go racing
:D Cheers :(
Edited by Sydneykid
http://mototuneusa.com/thanx.htm
for your info - 5 parts to the running-in of an engine, plus his advice makes sense.
Im not liable for blame if she blows! - but my bike engine loved me for it :P
Im not liable for blame if she blows! - but my bike engine loved me for it :(
Honda motorcycle engines rev to double the rpm of a Nissan RB
The tolerances that a motorcycle engine is built to are not the same as an RB
Honda motorcycle engines are not usually turbocharged
Don’t pussy the thing, lots of varying load is good, but not lots of rpm or boost.
:P cheers :D
:blush: cheers :blush:
I agree - not that that means much.
Lots of varying the RPM, ie the load on the engine, is the way to go. Never let it 'idle' drive, ie sit at 60kmph for 5mins at 2500rpm; vary the load.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
