hey guys, i know theres another thread but it didnt seem to be the right solution. im sure ive got it this time :P
i was sitting around wondering why sometimes while in 2nd it would drop into 1st and stays there, especially on bumpy roads or while going over speed hump. i also wondered why pushing the snow button shifts it into 2nd electronically.
i figured it would be something electrical rather than mechanical, so i thought i'd try the throttle position sensor and see where that takes me, so i loosened it, played with it a bit till my idle was sitting right again (adjusting your TPS adjusts your idle), i tightened it back up, took it for a drive and its been fine ever since. for some reason shifts are alot smoother too.
i did this 2 days ago and ever since its been fine.
what are your opinions? can someone with the sticky 1st issue try this and see if it works for them too?
https://www.sau.com.au/forums/topic/128698-auto-getting-stuck-in-1st-gear/
the snow button cuts first gear so when you take of in the snow or slippery conditions it stops wheel spin by taking off in 2nd
yep.
but i was saying thats how i get it out of first when it used to get stuck in 1st.
15) Once the car is warmed up disconnect the TPS (Throttle Position Sensor) See pic below circled in red, it is on the opposite side to where the throttle wire rotates the throttle butterfly.
See where the car idles. Now depending on where it's idling depends how you turn the screw (AAC one, not the computer one), turning it clockwise lowers the idle, anti-clockwise increases idle. You want to aim for 900rpm. Once you have this by adjusting the AAC idle screw, reconnect the TPS connection with the car running, see if the revs change. If they do, you're now going to have to adjust them on the computer (see this is why we got it out).
It's the OPPOSITE on the computer to the AAC valve screw: Clockwise=increase idle, Anti-Clockwise=decrease idle.
You can move the idle in 50rpm incriments so i'm told and at total variation of 250rpm, so DO NOT OVERTURN THIS COMPUTER CONTROLLED IDLE. This is only a fine tuning mechanism.
(Note if you have an R32, the connection you have to disconnect when adjusting the idle is actually the brown electrical connector on the AAC assembly, not the TPS)
I didn't actually need to move my computer controlled rev, as my revs didn't change once I put the TPS electrical connector back in.
i found that, its a good guide to re-adjust it.
i got it off here...
http://www.skylinesaustralia.com/forums/in...howtopic=110431
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
