hey troy, I just wanted to publicly let you know that this morning on the way to work today I felt this huge pressure down low. Because I got up really early I didnt have time to use the toilet. I really needed to relieve myself and in doing so I let off this gigantic fart, right into your seat. The propulsion of this fart actually lifted me off the seat.
Ive tried vacuuming, spraying, every deodorizing technique I can find, but this smell wont go away.
I nearly suffocated driving home today
Do you still want it back?
Had a look Yvette and I have my GTR Fuel rail but the buggers musn't have given me back the stock Fuel Reg.
You could try the Wanted to Buy section or maybe bite the bullet and by aftermarket for $100-$150 (Sard)
Thanks Sinista32, it seems stock ones don't get given back unfortunately... WidebodyGTR is going up to Sydney this weekend and is going to see if his tuner has one lying around - if not I'll part ways with a few bucks (I'm getting used to that with the 32 ;) ) and buy one. I'm running a Sard now but need to stock it up for engineering. Fun times! :)
Really? It's the first time for me getting a car engineered, so when I was told I'd need a standard fuel pressure reg I accepted what the engineer said. Have you guys had cars engineered with aftermarket regs?
Hey all finily after many of years I'm in a skyline but to get my beast passed for rego I belive my 20" rims won't pass so if any one has a full set of stock with good tyre maybe I could borrow for a day or two
PM'd.
  • 1 month later...
  • 4 weeks later...
Ok just received my vehicle from compliance took it to Dickson and they said this
Tint: Is too much
Exhaust: 94db
Spare wheel needs a sticker
Scissor jack needs a warning sign
Can i borrow someones scissor jack and the spare wheel. Ill have to work out the tint. If possible during the weekend or earlier.
Apparently i dont need an identity check so, just certificate of inspection. Does that mean i can take my car somewhere else where its likely to be passed because they are not some argo shits with hate on imports.
lol - that sucks.
Tint - meh ok if over 30-35%
Exhaust - wow that is so damn close I am seriously impressed.
It's good that it is realy minor mate. I wouldn't be complaining.
All in all an awesome result - but if it just came from being complied I'd take it back to them as it failed.
I have a rego muffler if you want to borrow
Ps no one needs to buy one, this one is never on a car.
Lets call it the community rego muffler
Edited by D.I.Y. Mik
So i toook my car to erindale service center thinking they would pass me but he couldnt do it since its never been registered in Australia.
Im taking it back there hopefully on friday
anyone have a spare jack i can borrow /hire for the day "it will be returned without you having to use force"
also a spare wheel with this 80KPH sticker on it too.
If i dont get a permant fix ill get in touch with you as i dont want to always get pulled over for it.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
