  • 1 month later...
  • 3 weeks later...
Anyone got a set of 4 wheels (preferably stock evo 8/9 wheels) with roadworthy tyres that i can borrow for a roadworthy inspection on monday. I just put the stock struts in and because the ride height has increased the front wheels sit well outside the guards now.
Im happy to leave my wheels with you for your peace of mind that they will be returned!
  • 1 month later...
Would anyone have a pair of Front Upper Control Arms i could borrow for a RWC,
They must be in perfect condition, as ive been pinned @ rego for less than 1mm of play before.
The assholes @ dickson did'nt like my Driftworks items!!! :( and have suggested i get an engineers report for them. im not wanting to do this for a couple of arms, would rather do it when the whole suspension system is done.
So, please help me out! Im really keen to get NORTON back to its former glory. :)
Thanks
Anthony
Any one have a stock front pipe and exhuast for a 32 its a rb25.
needed for rego thanks heaps!
Got a 32 stock dump and downpipe, and rego muffler.
Thanks
Anthony
What for? 32? i have arms with shagged bushes, and a box of new mystery bushes. dunno if they are control arm bushes.
Pm me for my number
Edited by D.I.Y. Mik
I have a vehicle inspection at dickson on monday morning so Has anybody got a set of standard R32 GTR wheels they are willing to lend/hire out?
I have a Diff back rego exhaust to suit R32 GTR with 3 bolt flange if anybody needs to borrow it
i have gtst wheels same just not forged, you may borrow mate
Thanks a heap but i actually just borrowed Robs R32 gtst wheels and they Rub slightly on the front brakes nissan logo of a GTR. i believe gtst wheels are 16x6.5 +40 and GTR wheels are 16x8 +30.
Thanks
rubbing slightly = fail
and spacers= illegal = fail
Thanks
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
