when i start the car up the idle drops after warm up time to bou 850 -900rpm.
after a while the revs will occasionally raise to a little above 1000rpm without touching the accelerator and if i turn the wheel when stopped the revs drop to bout 550 - 600rpm?
is this a problem because it gets relu anoying??
I have allready cleaned the acc valve so thats not the problem --> any other suggestions????
what else could be the problem??
https://www.sau.com.au/forums/topic/128735-idle-problems/
hey man,
look in the tutorial section for "Cleaning you AAC valve"
i can almost guarantee this will fix your problem.
after time the aac valve gets full of crud and carbon build up.
spray it out with carby cleaner and put it back together.
its easy as to do, im pretty useless at diy now i can do it in like 30 mins.
cheers
https://www.sau.com.au/forums/topic/128735-idle-problems/#findComment-2385637
hey man,
cheers
That could be something as simple as the idle up for the a/c compressor. Is the a/c on when this happen?
https://www.sau.com.au/forums/topic/128735-idle-problems/#findComment-2386029
as already said, the turning of the wheel is the cause of the revs dropping due to the power steering pump needing power.
when the revs go up do they stay there for a little while, or does it jump up and down? if it goes up and stays there for a while then drops, it could be the air con, as godzilla32 said.
https://www.sau.com.au/forums/topic/128735-idle-problems/#findComment-2390914
its not meant to...it explains why the idle drops when you turn the wheel
as mentioned i am sitting in the car start it up and sit there - dont touch the wheel dont put my foot on the cluch dont turn the a/c on - nothing
it still idles rough - jumps between 1000 and 600 rpm and sometimes misfires
https://www.sau.com.au/forums/topic/128735-idle-problems/#findComment-2405510
Hmm I have a similar problem (R33 gtst)
Start the car, works fine, cold, idles at 1100 or so. Warm, will idle at 900 rpm no worries. However, if im crawling at an intersection or in heavy traffic, if I move forward, then to stop just put the clutch in and stop, the revs drop not to idle like they should but to very low, like 200-500 rpm, the engine shudders abit, then jumps back upto 900rpm idle and is fine. But it keeps threatning to stall everytime it does this?
https://www.sau.com.au/forums/topic/128735-idle-problems/#findComment-2405760
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
