ok I just had my r33 gtst tuned with a few nice new bits like a new turbo, dump pipe, AFM, injectors and fuel pump, FMIC etc
ran it on 1bar and noticed the packs we dodgy but still got 260 out of it from 175 at 0.7bar on the previous setup. I dont pay too much attention of the dyno result but I got a gain of about ~90kwatw which I was happy with. I just wacked in the spitfires and will run it up tomorrow.
of course this is max power..my aim was good avg. power and some good low down torque - havn't got the graph but will run it again tomorrow.
do you think I should leave it or should I tune it for a bit less? I assume that if I don't ever really hammer it too much to 1bar - i.e. half throttle most of the time then it wont really cause me too many dramas. I actually only aimed for about 220...
Just intrested in some feedback and thinking about traction issues as my new wheels havn't arrived form Japan yet....
Chris.
https://www.sau.com.au/forums/topic/128738-how-much-is-too-much/
Can never have too much :happy:
By 260 are you talking kw? With what you mentioned & because you are over east that's what I'm guessing, which is pretty close to what I have/had. My car just seems to run perfect, almost as if I have traction control!! The only wheelspin is just before redline in first or second, it didn't take long for the tyres on there to be worn but I put on some toyo t1-r's & they were great.
yeah 260rwkw with doge packs. I have been focusing on the low to mid range as I'm not intrested in high end power as I don't take it to the max often. I will get all the exact details and the plots tomorrow when I head down after work. then u guys can have more info.
I told them to tune it the best the can for the moment...
Edited by khunjeng
What you need to consider is what you are setting the car up for, Drift, Drag or Curcit.
With that much power I wouldnt go anymore because your car is going to be a bitch to drive on the street, Altho some ppl like that :happy:
Also have you maxed out the turbo? Maybe you should look at some lumpy cams and do some head work then bump up the boost.
this is just for street use until I get the bug to do some track work...I will need to do some more work on the setup before then.
I'm not really intrested in more power. I think I have enough..I was actually considering lowering it but I will drive it first and see how it goes.
Edited by khunjeng
ok.
well I havn't got all the details of my turbo yet cos the guy who did it wasn't there when I picked up the car. I will have the full sepcs on monday. However is has a stock housing with a BB xx turbine plus some bigger inlets/outlets lol I'm not a guru on turbos - details to come.
Initially I was aiming for about 220 atw but when all the following mods were on it pumped out a fair bit more. Also I picked it up late so the dyno results will be posted when the some1 there gets a working printer! hehe
The first dyno run output 275kw and around 440nm of torque which was impressive. However at about 4500 the emange wasn't coping and there is a flat spot...but picks up again after 5000. Tried to smooth it out but essentailly the emanage couldn't do the job so power FC here we come..the dyno reuslts were intresting - sorry for no pics.
De-tuned it to about 250 to smooth out the response...the torque was great up to the 4500-5000 mark where the emanage screws around...generally it runs like a rocket!
anyway list of mods:
Custom turbo upgrade (lol details to follow)
Bosh fuel pump
VG30 AF meter
Apexi front pipe
cat back exhaust incl 730CFM cat + HKS muffler
600x300x76 FMIC
Emanage - when u see the dyno you will see it needs ot go!
Boost controller - just a manual bleed valve which shows it need to be replaced
Spitfires
Injectors - need the specs but I think they are 550cc?? sounds right or is this std.
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
