Right, well i've started installing a handbrake. it's not as easy as some people have made it out to be.
Firstly, i purchased the handbrake mount bracket. part number 34938 - AA200:
now, i found this part had too much in it. I needed to drill out the 2 spot welds on the left hand piece that goes on the passenger side of the transmission tunnel. I already had this piece of the bracket installed into the car.
now, to remove the old handbrake cable, first of all, remove the foot-brake. the handbrake cable needs to be detached underneath the car, which is quite easy, and there are 2 bolts holding it in underneath the airbag sensor. this sensor had TORX bolts holding it in on my car:
i had to get a T50 torx bit, and they came out fine.
and next, i noticed the bracket that the centre console attaches to sticks out a bit much:
i drilled the 3 spot welds for this out, and then wrestled to get it off the car:
now that was all out of the way, the bracket could finally be installed. there's some gooey crap on the tunnel, which i scraped off with a screwdriver, then drilled through the holes in the bracket into the tunnel. through these i put M6 bolts:
using a 5mm bit the bolt did screw into the tunnel a bit, but it's only very thin sheet metal, so i had to put washers and nuts on the other end. now this was no easy feat. i suggest removing the drive shaft, but as i only had car stands, i couldn't get enough leverage to remove the bolts. they're 17mm bolts so not something to sneeze at. anyway, i did manage to get the washers/nuts on, by gluing them to my finger and then screwing them on:
this is still to be continued. the handbrake i have lines up with the holes, but the brackets aren't flush. i'll just get the oxy to them and bend them in slightly, then she'll be right. i'll finally have a working handbrake. watch this space for my clutch installation....
hey terminal nice work mate u found the torx key i see :laugh: i was just wondering how much that bracket is worth from nissan new? i made my own but it still sits abit low in the console, and i might use that one if its easy to fit and also how do u know it will line up with console exactly? did u just drill new holes when u sat the bracket in the correct spot? does it sit up high enough to clear the console? the tailshaft is pretty easy to remove u just need 2 decent sized spanners to do it and watch ya knuckles :happy:
cheers
Brad
Edited by CruiseLiner
Sorry, the price is ~$50, depending on how nice your nissan dealer is. i think mine was upwards of $60, but i've heard of people getting it for less than $50.
i bolted it in and everything without thinking to line it up with the handbrake, and almost cried. luckily, it lined up perfectly! i can only assume since the handbrake lines up, the console will.
cheers mate thats pretty cheap i get trade price anyways, i was expecting $150 or so goin on normal nissan prices hehe :P
let us know when u try the console in place and whether it fits exactly right. my handbrake cable lined up perfectly but its just sitting too low to put a console surround on the gear shifter area and be able to fully release the handle down to disengage it. i havent got a manual console to try either, i dread spendin $750 on a piece of plastic :P ill buy one once i stop buying engine parts.
thanks
I might organise one day to meet up with one of the auto s1 owners, and we can both remove the consoles from our cars and compare them.
* Beastien lives close to 3hrs away.
* EGA41T already has a manual (s2) and according to Beastien my console is from an s2 anyway, so it'll probably be the same.
* R33stagea works at least 6 days a week, I think, which might make things difficult.
Any Sydney volunteers? SK? Fergo308?
u can cum ova and compare mine nick in about 4 weeks if thats not too late 4 ya
hmm my mounting bracket doesnt look anything like that........... but it fits perfectly in the space on the floorpan for it, pity it still isnt welded down properly.......... ~2mths and counting without a handbrake :) just waiting for a mate to get back from his 3mth mine stint and then get him to weld the bugger on so it aint ever going to come off :D
i didn't weld mine on because i would have to remove the front seats, rear seats to then remove the carpet section to prevent the carpet catching on fire when welding the plate on. i've still got to reinforce it with a few more bolts, but i needed a handbrake by the weekend, so i've opted for the bolts & washer method for now.
Yeah I am going the, "Buy a 5mm thick steel plate and cut and mould into shape, get 5 high tensile steel bolts, drill holes through foot of handbrake assy, steel plate and floor pan, put bolts though and tighten and tack the nuts on and then weld around the steel plate to the foot of the assy and the floorpan" way :(
I have 2 days set aside to remove the interior, weld it up and put it all back, mainly because most of the time we will be drinking, so have desegnated that work on the car only to be done when sober :D
yeah it would have taken me about 4 hours so far to remove interior and fix the plate. putting the handbrake back in should only take half an hour, so i'd guess to do it all in one hit, 5 hours. installing the manual console isn't a hard feat, neither is removing the auto one. it's the plate that took most of the time, and figuring out how the heck to attach it.
hey ska u dont need to remove interior at all, just weld the bracket base onto the handbrake assembly to give it more supports over a greater area and bolt it in using some good sized nuts and bolts, mines done this way and the bracket distributes the pressure enough that the floor pan will not move or warp when u keep pulling handbrake on and off over time.
haha, im not sure they would be ideal, its alot of force on the gearbox floorpan when handbrake is pulled up and also ska dont forget to use some big big washers on both sides to stop any chance of the nut pulling through the floorpan. for $50 i'd just buy the correct bracket and then u know its right and sitting in perfect position :)
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
