i've always had the impression "who'd want to steal from a volvo?" but it looks like there might be some theives out there who know what it really is.
i had my R33 broken into twice, both times losing the stereo and other assorted goodies. it really grinds my gears when i hear about that shit happening.
i hope it doesn't cost too much for replacements.
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2382038
Sorry to hear muck; I know exactly how you feel... I had my windows smashed in a theft attempt (they didn't steal anything though)... it's a complete pain in the arse to find the parts required - especially the rear quarter window!!!
Hope your insurance sorts it all out (if you're going that way) and your car is back on the road soon.
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2382053
Only thing to do with these type of people is to hang the fckers up by their balls!
Good to hear that they werent able to steal the car itself, still, some people have no bloody respect!
funny you said that hang them by the balls. i sue that expression as well when im really [issed of
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2384111
yeah guys fair enough your with shannons but nobody is answering the question why are they better? and i dont just mean price. I underwirte insurance for a large home and contents insurer and I want to know what the policy is like I am going to read both product disclosure statements but am interested in personal expeirences people have had as customer service and claims efficiency can also make a big difference I personally would pay more to get the best product and not just the cheapest
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2385882
Shannons gives you (from what I can remember):
* choice of repairer;
* first option to buy the wreck if your car is written off;
* higher level of third party property coverage (I think it's $20million, compared to $5million with JustCars)...
I'm sure there's more, maybe _800STED_ can give us a better idea of the differences.
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2387592
*1 free glass replacement a year
*much lower excess $500 compared to the $500 + $700 or some shit jci want.
*pay by the month
https://www.sau.com.au/forums/topic/128779-broken-glass/#findComment-2388064
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
