I have another motor coming in the next 6-8 weeks. If i dont sell the setup then i most likely just keep running it until i get back from OS when i can afford to respray the engine bay and throw the new motor/setup in. If its not sold then i would rather lend it to a friend for his R32 whilst the setup finds a buyer...rather then give it away cheaply
How much to Brissuie? Probably around $100-120 as it would all up weigh about 20kgs and take up a large carton about 600x450x450
  • 4 weeks later...
New timing belt and water pump going on motor in the next 10 days. Once the thing is retuned with the cams i will be keeping the setup until Sept-Oct. So any interested parties should contact me soon.
Out of interest, though i dont want to let it go much cheaper then my askign price...is the price the problem? Or is it noone likes Greddy setups??? PM responses if you could be bothered
been considering this since first view is this setup internall or external wastegate
any chance of pics of indivial parts if its all still for sale
its external gate.
its all on the car still so you might not get pics of separate parts...
This is The soarer kit but both include the same things, slighly differrent shape of course lol.
Killer kit.
Edited by URAS
  • 1 month later...
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
