Hi *wipes tear* All *wipe tear*
Just let go of my R33 GTR today and honestly nearly cried :(
My girlfriend looked at me like you're a bloody tool. Was they same when I sold my 33GTSt over a year ago.
What do you think makes us guys (and girls) attached to our bloody cars so much, they are only forms of transport and hunks of metal *slaps myself* :D Sorry had a moment then.
Luckily the guy that bought it lives in Perth so there is no chance of seeing it around and maybe stealing it back for another moment of passion together *slaps again*
Oh well back the corner to huddle in a ball and weep.
https://www.sau.com.au/forums/topic/128819-my-gtr-is-gone-has-my-life-ended/
  • Replies 40
Posted Images
There is nothing wrong with public transport... what could be more class than cruising around with 50 other people; driven by a professionally trained driver; being issued with your individual boarding ticket; and in a luxurious Merc/Volvo without seatbelts?
Best of all you get the lovely aromas that waft around - and if you're real lucky you might rub against someone who's sweating like a pig!
PS: your life is not over; you're still alive - you're just going to spend the rest of your life in misery :D
Just let go of my R33 GTR today and honestly nearly cried :angry:
She wouldnt understand, and its probably just her jealousy surfacing over you having a relationship with a car.....aswel as her :yes:
Go buy another one, you know you want to :blush:
(Best thread this week!)
im the same, i know finacially i should not have my car at all....i dont own a house, dont own anything but a car.....thats just crazy.
but i can not sell it...not now.......i guess im not strong enough mentally to do what is right..
at least you achieve what you wanted to achieve by selling it......maybe one day, you will get another one aye?
If your missus doesn't understand, maybe you should have just sold her instead....
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
