Ive recently picked up an rb25de and gearbox and am weighing up my possibilities.
Becuase I was disqualified from driving, I will come under the new P plate laws so I wanna build a quick NA car.
SO i was wondering if anyone can shed any light on a vl rb30 bottom end with the 32 non turbo engines top end.
Some questions I have are, what needs to be modified
how much will it cost
what power figures will it produce
quarter mile times?
If other people have done this and arent happy with the results please let me know so I don't waste my time and money
https://www.sau.com.au/forums/topic/128856-na-rb30de/
try a search.. there is meny threads about this.
both me and dondensoto have built this. plus i think there is another 1 or 2 guys floating around but i cant rember there user names.
cost depends on how much you do yourself and how far you go wtih building it.
quickness - mine can keep up with 150kw r32 gtst and similar cars plus some other more powerful and lighter cars.
is it worth it.. depends what your wanting from it and what you want to spend. if your wanting to build a super quick NA car get a honda
if your wanting a torquy, fun engine with plenty of power that revs pretty quick with the rb sound then this is what you want.
head will bolt staright on to vl bottom end.
i dont think it was a waste of $$ at all.
https://www.sau.com.au/forums/topic/128856-na-rb30de/#findComment-2387097
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
