Mod question
Guest R33 GTR V-SPEC
Hi guys,
I recently got an R33 GTR Vspec and im planning to modify it with the following:
1. 3.5" turbo back exhaust
2. Pod filters with carbon fibre heat shield
3. Apexi power fc
4. Apexi boost con @ 15psi
5. Larger intercooler.
With these mods does anyone have an idea of what power id be making @ the engine and approx what 1/4 mile time it would run?
https://www.sau.com.au/forums/topic/12886-mod-question/
Hi R33 GTR V-SPEC, The other guys have covered the power and 1/4 time pretty well. My suggestion would be don't change the intercooler, the standard R33 GTR intercooler is good up to 300 rwkw. With your plans you won't be anywhere near that. So keep the response up and stick with the standard intercooler.
The only weakness at your target performance level will be the clutch. Heavy, big power and 4wd puts a lot of load on the clutch. Standard clutch won't last very many launches. We use OS Giken twin plates for your sort of power level.
Hope that helps.
https://www.sau.com.au/forums/topic/12886-mod-question/#findComment-255370
Similar to what I'm going for, with that setup you should be pumping out around 240-250 rwkws, 330kw+ @ flywheel. I agree with sydneykid, don't change cooler, better spend that money on a twin plate clutch, standard one won't last with that sort of power and hard launches.
I'm going for nismo twin plate, from what I've heard they're not harsh on the left leg.
Also expect a mid to low 12 with that sort of power on the 1/4.
Hope that gives you a fair idea.
Cheers
https://www.sau.com.au/forums/topic/12886-mod-question/#findComment-255436
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
