Im in the process of getting my R34 GTT highflowed ( GCG). Since the exhaust housing is larger then the R33, I should be able to gain 30 odd extra rwkw . I have a 38mm tial wastegate laying around which i was going to use on a different setup but changed my mind. Im thinking of welding the internal shut and change to the external instead. Im assuming that this will allow for better boost control and maybe even push the turbo to around 280-290 rwkw. Could i still use the standard exhaust manifold and get it modifyied with the wastegate or get a custom one fabricated up? What cost are involed?
https://www.sau.com.au/forums/topic/128870-r34-gtt-gcg-high-flow/
An external wastegate does not increase turbo power.
A wastegate int or ext is there to regulate boost pressure. One does not make more power than the other in a correctly working situation.
If the turbo suffers from a int gate hole that is too small, boost control problems can arise.
Seeing as though no-one to date has reported issues, there is no need.
You can convert it to external if you want, people do weird things all the time.
However, you are mistaken if you think it will make anymore power.
Its that simple. How better boost control equals more power i dont understand. 20psi is 20psi. Doesnt matter what regulates it.
IMO, why butcher what is proven to be a superb turbo?
Ext gate with a screamer pipe will make more hp... however otherwise there is no point in it. A good new elc boost controller will be able to regulate ur boost settings fine, if you cant a actuator with a stronger spring then the elc boost controller onto that will do the job. I found abit more lag with the external gate so i wouldn't go down that route unless you REALLY love the noise and want around 10-15 more rwhp at most
and nothing else was changed?
was this peak power? average power? power lower in the rev range???
just when you think of what a wastegate does.... it controls boost
so unless it wasn't doing its job in the first place and the boost was dropping, there is nothing to explain the increase
To be honest... external gate brought power on later (around 300-500rpm) but controlled it MUCH better. I have 20psi from about 4500rpm to 8000rpm.
The increase was from having no restrictions in the exhaust, it went from a split 3' dump/front to a single 3' dump/front and the screamer comes off the ext wastegate, there is no mixing of the exhaust cause turbulance which is wat makes the exhaust wheel spin easier! Or so logic should go... lol
Edited by jazza08
I made 12rwhp from it...
If only i kept the old fkn dyno sheet damn it!! I was so proud of my new one i didnt keep the rest lol
12rwhp would suggest to me dynoing difference rather than an actual power increase.
Being you can go to the same dyno, a week apart, and the reading wont neccesarily be the same.
Damn posting while im typing.
If you had a restrictive exhaust, then thats where the gain came from.
It has absolutely nothing to do with the wastegate itself.
I bet you if you changed to a 3.5-4" exhaust keeping the internally gated turbo... you would see the same increase in power... all beit a poofteenth in your case.
As for boost coming on later, thats poor wastegate spring selection. im guessing, so your getting a bit of gate creep as it cant keep the thing shut long enough
oh well
back to the original issue ..
280-290 kw - sell the tial gate, spend a little extra on poncams.. and have a more streetable car that would have close to your power targets.. be very hard to defect and less fabrication costs ..
fabrication costs and first defect would pay for the rest of the cams anyway
see abo bob's r34 GTT 4 door Auto for comparison ..
Thinkin about that.. it may not be true because i never ran 20psi when it was internally gated... full boost was more around 15psi and made that abit earlier as you'd expect. Ah well im happy with the result for now, on the issue id also say cams are a better option than spendin money on gate etc if hp/driveability is ur main goal
Each post you make you give more information... :sorcerer:
Next time put it all into one post next time, makes it easier to make a comment on it all rather than posting little snippets each time you reply until we get the full story a half a dozen posts later :rofl:
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
