hey ken (RBNT) good luck with the run in and make sure to let us know how the final tune goes :D then get it down the drags and run some good numbers :) go the mighty stageas. have u put yours on a weight bridge by any chance to see how much the autech weighs compared to the rs4? my rs four as it is, is 1690kg without a driver and half tank of fuel.
  • Replies 61
  • 2 months later...
  • 1 month later...
Updated all repairs and added to modlist
Modification List:
Mongoose M80G with glass break sensor
Nissan Stagea 260RS Dash
Nissan Stagea 260RS centre console and handbrake assembly
Nissan R32 GTR gearbox with Nismo Heavy Duty Gearset and C-West short shift kit
Nissan R34 GTR pedal box
Nissan R34 GTR clutch master/slave
Nissan GTR Drive Shafts
Nissan GTR Rear Differential
Nissan GTR CV Arms and Joints
Nismo High-Volume R33 GTR fuel pump
Apexi Power FC Engine Management ECU
K&N Extreme Suction Pod Filter
Hybrid Front Mount Intercooler 800x600x80, with Custom 2.5” Piping
GFB StealthFX Blow Off Valve
Splitfire Ignition Coils
NGK Platinum Spark Plugs
Gabwagon Adjustable Coilover Suspension
Whiteline Adjustable Castor Rod Bushes
Koya Octane Hyper Wheels 18x8
Custom 3” Turbo Back Exhaust (inc 3” Dump & High Flow Catalytic Converter) with 4” Stainless Steel Tip
Pioneer DEH-P6250 head unit
Blitz Turbo Timer
DRIFT Boost Gauge
Custom Cold Air Intake Barrier & Feed
TurboTech Boost Controller
Nismo Clear Side Winkers
Aftermarket Clear Front indicators
MTX 2 way front 6" speakers & Pioneer 2 way rear 6" speakers
To Fix:
Fit rear camber bushes and raise to improve the 13mm ground clearance it has atm
Buy gauge holder from qikstagea and fit boost gauge properly, instead of zippy ties
Remove top cooler pipes and paint matte black
Remove bright blue GFB Stealth BOV and spray black
Remove bright blue Turbo Tech BC and spray black
Wishlist:
Whiteline Adjustable Camber Bushes - Front
Custom Rear Wing - $200
Z32 AFM - $300
Bigger injectors - $700
Fuel pressure regulator - ?
Tomei Pon Cams or HKS step 1 Cams - $900
GT3076R - $1800 including braided lines and modified inlet
Dyno Tune - Matt Spry $800
DBA + Brembo Brakes
Front Bar - 260RS
Side Skirts - Nismo
Just waiting on sale of left nut to buy all the wishlist items :laugh:
Edit: Updated all repairs and added to modlist
I highly highly doubt you have 13mm of ground clearance Cyrus.
Thats 1.3cm mate!
I've got 100mm (the legal minimum here in VIC) at a few points in the car. Tempted to lower it slightly more, but then my brand new jack wont fit under the cross member any more... decisions decisions.
ad a low VN a few years back and had to make up small wooden ramps so we could get the jack under the front bar. Drive on to ramps, then jack it up. As long as the emergency jack still fits under!
Cheers
Luke
Getting the valve clearances redone, its too noisy to hear knock on the 'phones so I cant run high boost through it. Once its fixed ill throw 22 pound at it and see if I can break the 400rwkw mark.
You are right alex, now I have 1.7cm or 17mm of clearance thanks to qld fcuked up roads and a couple of big whacks in the exhaust.
Now that I have rear camber bushes (thanks to darrin) I'll be raising it to at least a good inch or two. stupid freakin qld crap road, national discrace, not national highway.........
you're whinging about crap roads because of a discrepancy of 17mm in height over a length of 2720mm (wheelbase of your car)?
:P
Not really whinging, I knew my car is too low, hell if there is a slight bump in the road I'll bottom out, just got really annoying that on a national highway I had to drive on the humps so that I was not constantly bottoming out, and even then I did bottom out several times.
Time to raise it :P
Man you are starting to post sentances like Yudy and Hugh, I'll translate for those who cant speak icanttypish:
Ska, Was the compression test only done because you had some time on your hands or does the motor have some symtems?
Nah there was a tiny bit of oil in the top of the radiator so just wanted to know if it had come from the motor or if I had a head gasket problem, also if potential buyers wanted to know what the results of a compression test would be I have what they were 2 weeks ago so that they can compare them to any results they might get.
I had a bit of spare time and had access to all the equipment for doing it, (Marc (Revhead) Dad's whole workshop), so thought why not get it done.
Future plans?? BUY A NEW ONE.
Cheap autech 260. S1, cheapest i can find.
Rebuild engine with big single turbo.
R34 GTR front end conversion from MASA.
Pump rear guards a lil, fit some matt black or black chrome dishy wheels
Paint it silvery blue, really light, bit of a pearl in it.
Try to get complete untinted windows, like Newbies. Leave em clear.
Put my stereo with custom box, 6 amps 4 subs etc which was sitting AT WORK WAITING TO BE PUT IN after being painted, in the back.
Time - two years
$$$$ - more than my first attempt
New number plates - [ROUND 2] - for obvious reasons.
  • 6 months later...
When i got the Stagea from Chris it had:
Fujitsubo Cat Back
High Flow Turbo
Some form of aftermarket coilovers
18" Work rims
Jaycar DFA
Jaycar EBC
I have sitting here ready to go on :P :
BOS Stainless Split Dump
BOS Catco CAT
ARC Frount Mount
Thermal Flex Blue 4mm and 6mm vac hose
Davies Craig Auto Cooler (came with the car from chris but was not installed)
Stagea Air Deflector (still waiting to hear from Bass Junky like everyone else)
Before the end of the year i plan to have these mods bought and installed:
Oil cooler and relocation kit
Defi Gauges (boost, oil temp, oil pressure)
EBC (get rid of jaycar one)
Whiteline swaybars and camber and castor kit
Trust PE11 Catback (hopefully)
Personalised Plates
Anything else my parents/siblings or relatives might get me for my 21st
Hopefully one day i will get these (distant future mods ) :D :
Manual Conversion (early next year if i dont buy a second car)
Power FC
New Wheels
Better brakes or stainless lines
Re-Spray
Thats about all i can think of at the moment as i do more ill update.
And if ive forgotten anything and i remember ill update :P
Well its been a while since ive updated my mods list, so i thought i would bump an old thread see what you guys think of my new mods and hopefully you guys can comment and im hoping some new members can also post up their plans!
So basically ill just write up my new mods and what they are replacing if they are replacing any at all!
Mods:
The Work wheels that where on the car when i got it, i got rid of them late last year for some 18" Chromies which are now for sale as i have just purchased some R32 GTR Wheels which should be here sometime this week.
Ive got myself a new HKS HI POWER exhaust on the way which also should be here this week. so that will be replacing the Fujitsubo cat back that i have which is already sold to another member.
32/33 GTR Seats which i should have within a couple of weeks
Ive bought a sillicon intake pipe in the Bass Junky group buy which will obviously replace the stock item.
Ive got some R34 GTT Rear calipers and rotors sitting in a box in my room just waitng to be fitted
I never ended up getting DEFI gauges instead i bought some nice Autometre cobalt gauges, ive got a Z32AFM sitting in my room waiting to be fitted, next to that there is an SITC waiting to be fitted but both of these items wont be fitted until i get an SAFC.
Ive also fitted a DVD headunit since last year.
I think thats evrything but if ive forgotten something ill add it in
Ohh...the hopes and dreams thread... HERE WE GO:::
um.. fix my cat and back zaust (kinda melting my rear bar at the moment)
fix a ding from the previous owner (small bit of panel work)
new spark plugs (i left the 02 sensor unplugged and i fouled my new iridiums ;) )
big 100K service (to be safe)
then
dump+front (paid for, just waiting on it to be fabbed up by a mate)
SK suspension kit (this year)
Emanage Ultimate + tune (this year)
MANUAL CONVERSION (this year)
should total about 6 grand :) start to finish
then later - when i get moneys
FMIC
VG30Ball bearing High flowed
fuel pump, Z32, splitfires to support it etc
LSD
torque split controller
NISMO KIT and respray
guages :)
maybe a sub :(
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
