hey ken (RBNT) good luck with the run in and make sure to let us know how the final tune goes :D then get it down the drags and run some good numbers :) go the mighty stageas. have u put yours on a weight bridge by any chance to see how much the autech weighs compared to the rs4? my rs four as it is, is 1690kg without a driver and half tank of fuel.
  • Replies 61
  • 2 months later...
  • 1 month later...
Updated all repairs and added to modlist
Modification List:
Mongoose M80G with glass break sensor
Nissan Stagea 260RS Dash
Nissan Stagea 260RS centre console and handbrake assembly
Nissan R32 GTR gearbox with Nismo Heavy Duty Gearset and C-West short shift kit
Nissan R34 GTR pedal box
Nissan R34 GTR clutch master/slave
Nissan GTR Drive Shafts
Nissan GTR Rear Differential
Nissan GTR CV Arms and Joints
Nismo High-Volume R33 GTR fuel pump
Apexi Power FC Engine Management ECU
K&N Extreme Suction Pod Filter
Hybrid Front Mount Intercooler 800x600x80, with Custom 2.5” Piping
GFB StealthFX Blow Off Valve
Splitfire Ignition Coils
NGK Platinum Spark Plugs
Gabwagon Adjustable Coilover Suspension
Whiteline Adjustable Castor Rod Bushes
Koya Octane Hyper Wheels 18x8
Custom 3” Turbo Back Exhaust (inc 3” Dump & High Flow Catalytic Converter) with 4” Stainless Steel Tip
Pioneer DEH-P6250 head unit
Blitz Turbo Timer
DRIFT Boost Gauge
Custom Cold Air Intake Barrier & Feed
TurboTech Boost Controller
Nismo Clear Side Winkers
Aftermarket Clear Front indicators
MTX 2 way front 6" speakers & Pioneer 2 way rear 6" speakers
To Fix:
Fit rear camber bushes and raise to improve the 13mm ground clearance it has atm
Buy gauge holder from qikstagea and fit boost gauge properly, instead of zippy ties
Remove top cooler pipes and paint matte black
Remove bright blue GFB Stealth BOV and spray black
Remove bright blue Turbo Tech BC and spray black
Wishlist:
Whiteline Adjustable Camber Bushes - Front
Custom Rear Wing - $200
Z32 AFM - $300
Bigger injectors - $700
Fuel pressure regulator - ?
Tomei Pon Cams or HKS step 1 Cams - $900
GT3076R - $1800 including braided lines and modified inlet
Dyno Tune - Matt Spry $800
DBA + Brembo Brakes
Front Bar - 260RS
Side Skirts - Nismo
Just waiting on sale of left nut to buy all the wishlist items :laugh:
Edit: Updated all repairs and added to modlist
I highly highly doubt you have 13mm of ground clearance Cyrus.
Thats 1.3cm mate!
I've got 100mm (the legal minimum here in VIC) at a few points in the car. Tempted to lower it slightly more, but then my brand new jack wont fit under the cross member any more... decisions decisions.
ad a low VN a few years back and had to make up small wooden ramps so we could get the jack under the front bar. Drive on to ramps, then jack it up. As long as the emergency jack still fits under!
Cheers
Luke
Getting the valve clearances redone, its too noisy to hear knock on the 'phones so I cant run high boost through it. Once its fixed ill throw 22 pound at it and see if I can break the 400rwkw mark.
You are right alex, now I have 1.7cm or 17mm of clearance thanks to qld fcuked up roads and a couple of big whacks in the exhaust.
Now that I have rear camber bushes (thanks to darrin) I'll be raising it to at least a good inch or two. stupid freakin qld crap road, national discrace, not national highway.........
you're whinging about crap roads because of a discrepancy of 17mm in height over a length of 2720mm (wheelbase of your car)?
:P
Not really whinging, I knew my car is too low, hell if there is a slight bump in the road I'll bottom out, just got really annoying that on a national highway I had to drive on the humps so that I was not constantly bottoming out, and even then I did bottom out several times.
Time to raise it :P
Man you are starting to post sentances like Yudy and Hugh, I'll translate for those who cant speak icanttypish:
Ska, Was the compression test only done because you had some time on your hands or does the motor have some symtems?
Nah there was a tiny bit of oil in the top of the radiator so just wanted to know if it had come from the motor or if I had a head gasket problem, also if potential buyers wanted to know what the results of a compression test would be I have what they were 2 weeks ago so that they can compare them to any results they might get.
I had a bit of spare time and had access to all the equipment for doing it, (Marc (Revhead) Dad's whole workshop), so thought why not get it done.
Future plans?? BUY A NEW ONE.
Cheap autech 260. S1, cheapest i can find.
Rebuild engine with big single turbo.
R34 GTR front end conversion from MASA.
Pump rear guards a lil, fit some matt black or black chrome dishy wheels
Paint it silvery blue, really light, bit of a pearl in it.
Try to get complete untinted windows, like Newbies. Leave em clear.
Put my stereo with custom box, 6 amps 4 subs etc which was sitting AT WORK WAITING TO BE PUT IN after being painted, in the back.
Time - two years
$$$$ - more than my first attempt
New number plates - [ROUND 2] - for obvious reasons.
  • 6 months later...
When i got the Stagea from Chris it had:
Fujitsubo Cat Back
High Flow Turbo
Some form of aftermarket coilovers
18" Work rims
Jaycar DFA
Jaycar EBC
I have sitting here ready to go on :P :
BOS Stainless Split Dump
BOS Catco CAT
ARC Frount Mount
Thermal Flex Blue 4mm and 6mm vac hose
Davies Craig Auto Cooler (came with the car from chris but was not installed)
Stagea Air Deflector (still waiting to hear from Bass Junky like everyone else)
Before the end of the year i plan to have these mods bought and installed:
Oil cooler and relocation kit
Defi Gauges (boost, oil temp, oil pressure)
EBC (get rid of jaycar one)
Whiteline swaybars and camber and castor kit
Trust PE11 Catback (hopefully)
Personalised Plates
Anything else my parents/siblings or relatives might get me for my 21st
Hopefully one day i will get these (distant future mods ) :D :
Manual Conversion (early next year if i dont buy a second car)
Power FC
New Wheels
Better brakes or stainless lines
Re-Spray
Thats about all i can think of at the moment as i do more ill update.
And if ive forgotten anything and i remember ill update :P
Well its been a while since ive updated my mods list, so i thought i would bump an old thread see what you guys think of my new mods and hopefully you guys can comment and im hoping some new members can also post up their plans!
So basically ill just write up my new mods and what they are replacing if they are replacing any at all!
Mods:
The Work wheels that where on the car when i got it, i got rid of them late last year for some 18" Chromies which are now for sale as i have just purchased some R32 GTR Wheels which should be here sometime this week.
Ive got myself a new HKS HI POWER exhaust on the way which also should be here this week. so that will be replacing the Fujitsubo cat back that i have which is already sold to another member.
32/33 GTR Seats which i should have within a couple of weeks
Ive bought a sillicon intake pipe in the Bass Junky group buy which will obviously replace the stock item.
Ive got some R34 GTT Rear calipers and rotors sitting in a box in my room just waitng to be fitted
I never ended up getting DEFI gauges instead i bought some nice Autometre cobalt gauges, ive got a Z32AFM sitting in my room waiting to be fitted, next to that there is an SITC waiting to be fitted but both of these items wont be fitted until i get an SAFC.
Ive also fitted a DVD headunit since last year.
I think thats evrything but if ive forgotten something ill add it in
Ohh...the hopes and dreams thread... HERE WE GO:::
um.. fix my cat and back zaust (kinda melting my rear bar at the moment)
fix a ding from the previous owner (small bit of panel work)
new spark plugs (i left the 02 sensor unplugged and i fouled my new iridiums ;) )
big 100K service (to be safe)
then
dump+front (paid for, just waiting on it to be fabbed up by a mate)
SK suspension kit (this year)
Emanage Ultimate + tune (this year)
MANUAL CONVERSION (this year)
should total about 6 grand :) start to finish
then later - when i get moneys
FMIC
VG30Ball bearing High flowed
fuel pump, Z32, splitfires to support it etc
LSD
torque split controller
NISMO KIT and respray
guages :)
maybe a sub :(
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
