I just bought a set of Porsche GT3 6 pot brakes, they came with brackets for 373mm rotors, and they don't fit under my wheels.
So I’m going to need new brackets made up. I'm going to get the brackets made up so that the pistons on the calliper are in the right order (all the ones I’ve ever seen on skylines have them on in reverse). I'm also getting new brake fluid lines made up, so I can put the bleeders in the right spot.
I was wondering if there was anyone else interested in doing this, as I could set up a group purchase to make it cheaper.
Or if anyone has already done this, and has contacts who has the plans/jigs to make these.
https://www.sau.com.au/forums/topic/128879-porsche-gt3-6-pots/
1 big problem, I live in Tassie. A hydrolic place is making up the fluid lines next week, but the bracket to hold them the right way up might be to hard to make. As the Porsche brakes don't have semetrical connectors. But i'm not giving up yet.
i'll do a ring round on monday, unless people work on sundays on the mainland. I just managed to fit my wheels over the brackets i got with them, but i'm still gunna try and get the ones made up so they are on the right way.
Edited by sav man
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
