I just bought a set of Porsche GT3 6 pot brakes, they came with brackets for 373mm rotors, and they don't fit under my wheels.
So I’m going to need new brackets made up. I'm going to get the brackets made up so that the pistons on the calliper are in the right order (all the ones I’ve ever seen on skylines have them on in reverse). I'm also getting new brake fluid lines made up, so I can put the bleeders in the right spot.
I was wondering if there was anyone else interested in doing this, as I could set up a group purchase to make it cheaper.
Or if anyone has already done this, and has contacts who has the plans/jigs to make these.
https://www.sau.com.au/forums/topic/128879-porsche-gt3-6-pots/
1 big problem, I live in Tassie. A hydrolic place is making up the fluid lines next week, but the bracket to hold them the right way up might be to hard to make. As the Porsche brakes don't have semetrical connectors. But i'm not giving up yet.
i'll do a ring round on monday, unless people work on sundays on the mainland. I just managed to fit my wheels over the brackets i got with them, but i'm still gunna try and get the ones made up so they are on the right way.
Edited by sav man
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
    • I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
