well you cant use the injectors without the P FC, you wouldn't want to use the injectors without the turbo AND Power FC
so you really only have the option of the power FC which will really limit what you can get anyway ...
save up for and get all 3 at once
https://www.sau.com.au/forums/topic/128886-what-to-do-next/#findComment-2384450
ye true so really its not worth doing anything now unless i do all three at once how much gain do u recon i would get with just the power fc and standard turbo on 12 psi i can get it rerally cheap and tunining really cheap thats y i was thinking just do power fc and do the rest later
https://www.sau.com.au/forums/topic/128886-what-to-do-next/#findComment-2384467
airflow makes more power not an ecu.
you will certainly gain a good stack of midrange and maybe a touch more max rear wheel power, but dont expect much more.
if you tune a big wad of the load points it will drive like a new car.
ignition and fuel points :)
https://www.sau.com.au/forums/topic/128886-what-to-do-next/#findComment-2384478
