After returning from europe and picking my car up from the paint shop it has started to misfire on boost. now while i was away an auto electrician was called in, with out me knowing, to take a look at a problem with the car not starting which he ended up replacing the plugs with NGK platinums? (are they good?) which apparently fixed the starting problem....
anyways driving it home when hitting any boost over 0.4bar it would misfire.
now a theory i have is this misfiring only seems to happen when the injectors are at full duty cycle, the reason being is i have a tomei eprom which runs very rich. to my understanding its programmed to dump max fuel soon as the turbo spools up. when i got home i swapped the eprom for a toshi one i recently got thats tuned alot leaner but rich at hi boost (at my request) and the problem was gone but only when running upto 1.08 bar. when i turn the boost up over 1.1bar the problem reappears...
now its an RB20 with a hks2510 and GTR injectors 040pump so im assuming at 1bar with the leaner toshi tuned eprom the injectors are yet to reach max duty cycle but anything over that the injectors are at max duty which is where the problem occurs.
i have also been told that maybe the gap of the plugs fitted may be the cause of the misfiring but why would the problem behave differently between the 2 eproms, unless these particular plugs cant cope with all the fuel ?!?
im yet to learn generally about spark plug gaps and associated tuning problems.
maybe a semi blocked injector?
both the panel shop and auto sparky have claimed no responsability as the car ran ok whilst in their care. (moving it around the yard at idle).... MOFO's
any help appreciated guys!!
Edited by BSK
The gap on the plugs might be too big and causing the mis. Aim for around 0.8mm gap. But i dont think you can modify platinum plugs, cause the coating can crack off. Try a set of plain coppers.
if the gap is too big then shouldnt it miss more often/randomly? or is the over fueling effecting the lack of spark between the large gap .. kinda like flooding the chamber with too much fuel causing an insulating effect on the plug?
Chances are that it was started cold everyday and not driven enough to clean the plugs so they are probably just a little fouled. There could be fuel and timng differences between the two maps the more fuel in the chamber the harder it is to ionise the gap - the same rule applies with less ignition timing.
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
