2 Boost Gauges?.... Shouldnt Only 1 Be Working?
Beef
 Share
Hey Ladz,
just a simple question...
when you buy and install an aftermarket Boost Gauge... where exactly should you hook it into and should your standard boost gauge stop working once it is installed?
i have just had a boost gauge installed but my little stock boost gauge under my tacho still works.....
should it?
or has the guy installed it into the wrong place or something?
Beef
Edited by Beef
depending on the car (assuming its a 33 if gauge under tacho)
32s run boost gauge off the map sensor on firewall
people t in the gauge in lots of different places.
i have 2 working boost gauges also
yeah both gauges will work. they're just running off the vaccum line from the manifold.
ok well if they are both reading wouldnt they be reading slightly less than what they should..... this is what im thining...
becuase you have 2 sources from teh vacuum line wont the reading be a little wrong because the pressure is being divided into the two different gauges?
why not just have one and remove the stock boost gauge and just block the tee that was using? wouldnt this give you a slightly more accurate reading if you only have one gauge feeding off the vacuum line?
Beef
well the stocker gauge is probably totally out anyway :P
and no, the reading will hardly be altered by a few extra cm's of hose and two gauges.
correctttt
on a side note... R31Nismoid, your avatar still makes me gag when i see it. damn, please change it. :rofl:
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
