Hey Ladz,
just a simple question...
when you buy and install an aftermarket Boost Gauge... where exactly should you hook it into and should your standard boost gauge stop working once it is installed?
i have just had a boost gauge installed but my little stock boost gauge under my tacho still works.....
should it?
or has the guy installed it into the wrong place or something?
Beef
Edited by Beef
yeah both gauges will work. they're just running off the vaccum line from the manifold.
ok well if they are both reading wouldnt they be reading slightly less than what they should..... this is what im thining...
becuase you have 2 sources from teh vacuum line wont the reading be a little wrong because the pressure is being divided into the two different gauges?
why not just have one and remove the stock boost gauge and just block the tee that was using? wouldnt this give you a slightly more accurate reading if you only have one gauge feeding off the vacuum line?
Beef
well the stocker gauge is probably totally out anyway :P
and no, the reading will hardly be altered by a few extra cm's of hose and two gauges.
correctttt
on a side note... R31Nismoid, your avatar still makes me gag when i see it. damn, please change it. :rofl:
