I recently replaced the clutch in my R33 GTST skyline. The new clutch kit consists of an Xtreme pressure plate and heavy duty organic clutch plate. the flywheel is a Xtreme Cr-moly item and weighs 5.5Kg. the whole assy is smaller than the high performance Nismo clutch i pulled out. the diameter is the same as stock on the new one but isn't as deep. also got a new thrust bearing. the problem i'm having is while the engine is running i can't put the car in gear. the clutch isn't dis-engaging fullly. i was wondering if anyone out there has had this problem before. i've checked over the hydraulic side and found a faulty master cylinder. I replaced the master and slave cylinders. anyone have any ideas? i'm an apprentice mechanic so i know what i'm doing but this one has me stumped. HeLp!?!?!? thanks... I've also put calls in to various mechanics in NSW that work on skylines everyday and they think if it isn't a hydraulic issue the next thing is the thrust bearing carrier. does anyone have any sizes for the carriers as i've been told there are about 10 different ones
https://www.sau.com.au/forums/topic/128921-clutch-problems/
I had the same problem when i installed my clutch.
To fix it i just adjusted the clutch pedal, make it so it pushes the clutch in furthur.
(There will be a bolt you have to undo a bit, if you have a look under there you will see what is needed)
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2386722
I tend to agree with the "various mechanics" - it's a problem of the wrong carrier.
You will need to pull the gearbox out anyway, then take measurements to work out which "height" carrier you need.
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2389053
i was afraid of that... pulling the box back out. before that i think i might have to adjust the pedal a bit.. it feels good through the whole travel.. like from the top to the very bottom. its never felt that good. This is so crap guys!! a car like this wasn't built to sit in the rear carpark of a mechanics workshop while the owner figures out the problem.. ITS NOT RIGHT
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2392795
can anyone tell me if this is a twin plate clutch? i've only every seen them in magazines and assembled.. this one seems to be sealed. as you can see from the pictures there are a few signs that it is indeed a twin plate clutch and if it is i may have solved the problem. so if you could take a few minutes to have a look at the photos and post a reply it would be greatly appreciated.. Excuse the pics.. they were taked with my mobile phone
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2395956
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2395964
Hey all... Sorry to steal the topic for a bit but ive been searching every where on how to adjust the clutch friction point, and have read few threads that all say do a search, i have a feeling those threads have been lost or deleted can any one give me a few hints how 2 adjust the clutch ? P.s is this link accurate ?
http://babelfish.altavista.com/babelfish/u...%2fcl-pedal.htm
https://www.sau.com.au/forums/topic/128921-clutch-problems/#findComment-2396064
    • Yep, there's a very minor drift left that happens a few seconds after letting go of the steering wheel, but not enough to bother me. Enjoying the car still!
    • Got you mate. Check your email!
    • I see you've never had to push start your own car... You could save some weight right now...
    • Sounds good.  I don't 100% understand what your getting at here. When you say, "I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down" do you mean this - there is a panel with factory paint, without any prep work, they paint the entire panel with primer, then colour then clear?  If that's what you mean, sure it will "stick" for a year, 2 years, maybe 3 years? Who knows. But at some stage it will flake off and when it does it's going to come off in huge chunks and look horrific.  Of course read your technical data sheet for your paint, but generally speaking, you can apply primer to a scuffed/prepped clear coat. Generally speaking, I wouldn't do this. I would scuff/prep the clear and then lay colour then clear. Adding the primer to these steps just adds cost and time. It will stick to the clear coat provided it has been appropriately scuffed/prepped first.  When you say, "but the new paint is landing on the old clearcoat" I am imagining someone not masking up the car and just letting overspray go wherever it wants. Surely this isn't what you mean?  So I'll assume the following scenario - there is a small scratch. The person manages to somehow fill the scratch and now has a perfectly flat surface. They then spray colour and clear over this small masked off section of the car. Is this what you mean? If this is the case, yes the new paint will eventually flake off in X number of years time.  The easy solution is to scuff/prep all of the paint that hasn't been masked off in the repair area then lay the paint.  So you want to prep the surface, lay primer, then lay filler, then lay primer, then colour, then clear?  Life seems so much simpler if you prep, fill, primer, colour then clear.  There are very few reasons to go to bare metal. Chasing rust is a good example of why you'd go to bare metal.  A simple dent, there is no way in hell I'm going to bare metal for that repair. I've got enough on my plate without creating extra work for myself lol.
